Author Topic: Can anyone find the rest of my plug?  (Read 10145 times)
Offline Nick_S
  • 189.6 bhp @ 8psi boost
Re: Can anyone find the rest of my plug?
« Reply #45 on: June 08, 2011, 10:50:58 pm »
Is that how much a vag oil pump is nowadays :o I do miss VagParts.com :(
Gutted for all this to happen to you, hope it doesn't stop you getting where you were aiming for though!
Offline Jezza-7
« Reply #46 on: June 08, 2011, 10:59:41 pm »
Really? I thought they were less than that.
I have got one that i bought a while ago. Its not new though. Will pop round at some point mate.
This will not stop me though nick. Plan is to rebore bottom end with forged pistons then get another bvh.
Offline Jezza-7
« Reply #47 on: June 09, 2011, 11:32:03 am »
Been looking at forged pistons and was wondering if it would be worth buying this package?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=380255270493&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en#ht_1466wt_907
« Reply #48 on: June 09, 2011, 11:35:47 am »
not really sure what the point would be, I've never known anyone have problems with the standard g40 rods
Offline Jezza-7
« Reply #49 on: June 09, 2011, 11:38:53 am »
Ok thats good to know.
Just a quick one as i got confused while reading a thread on rebuilding a bottom end.
Can you use a standard block, crank and con rods with 77mm forged pistons?
I think i was getting confused with the 1w crank etc and the height of them too.
Offline Robin
  • 194bhp - 1341 Turbo
« Reply #50 on: June 09, 2011, 12:44:49 pm »
yup.
Offline Boris
« Reply #51 on: June 09, 2011, 03:37:00 pm »
I got a vag oil pump from euro car parts for £90
Offline dub-disaster
« Reply #52 on: June 09, 2011, 04:17:33 pm »
That's a good price for genuine vag, I first bought a pattern kolben schmidt one and it was real crappy quality compared to genuine
Offline Jezza-7
« Reply #53 on: June 09, 2011, 04:52:54 pm »
VW have said £130.
Gonna get a list of everything i need as if i can get it cheaper from vw then it might save me some money plus i know its all genuine stuff.
Offline Andy
« Reply #54 on: June 09, 2011, 05:09:13 pm »
Did Jabba offer to repair/replace their faulty head? Or is there no warranty?
Offline Jezza-7
« Reply #55 on: June 09, 2011, 06:30:43 pm »
Still waiting to hear back from them but got no receipt so cant really prove they did it. I think he said send it in and they will see if it is repairable. Probably not but might give it a try.
Offline Jezza-7
« Reply #56 on: June 09, 2011, 06:46:16 pm »
So far i have a list as follows:
Wossner forged pistons incl guedon pins, piston rings
Crank Bearings [Set of 5]           026 198 491 A
Con Rod Bolt                            052 105 425 A
Hex Nut [Rod Bolt]                    052 105 427
Bearing [Rod to Crank]               031 105 701 A
Thrust Washers                         026 198 421
bush between crank and flywheel 052 105 313
oil pump                                   030 115 105E
Oil Pump Drive Chain                  030 115 125A
How many do i need of each and is there anything else i need? All help will be great.
Offline Jezza-7
« Reply #57 on: June 10, 2011, 01:21:18 pm »
Any suggestions?
« Reply #58 on: June 10, 2011, 01:46:11 pm »
you need bottom end gaskets and also need a timing betl pulley bolt and flywheel bolts.
« Reply #59 on: June 10, 2011, 02:45:38 pm »
Main bearing cap bolts
