Starter not working full stop!
Started by G40 AD, March 17, 2010, 11:39:01 AM
G40 AD
right quick update...
happy to see that i got a 12v reading with the engine off and 14v with the engine on!
I can only guess though that this means it isto do with earthing as sufficient power should be going through the starter motor if the alternator can still produce 14v??? am i correct in thinking this?
going to fit new wiring now just for piece of mind!
G40 AD
ok... just had the relays off and they looked a bit grubby/greeny so cleaned them and the sockets... is there a way of testing them?
just tested;
negative to starter: read 12v(engine off)
negative to alternator: read 12v(engine off)
my assumption from this is that the wiring is all ok, is this a fair assumption?
potentially it could be shorting at some point and still read 12v, correct?
going to clean up the bat terminal but cant see that i would get the 12&14v readings if a poor connection was causing trouble... grrrrrrrrrrrr..........help!
supercharged spaniel
ad have you check the earth straps around the bay?
G40 AD
yeah,
charger to chasis leg
bat neg to wing
coil to gearbox
that all of them?!? is there any particular way to test them? like bat posi to far side of earth n check the voltage?
cheers,
ad
Richg40
Quote from: youngprodigys on April 13, 2010, 06:52:19 PM
scirocco glx alternator is exactly the same as g40. £37 brand new of eBay - allllllright:-)
if it was doing it when hot- check the wire going from the alternator to the starter. it runs along the sump and the plastic goes manky near the clips and you may find the wire has frayed near them potentially causing a short. I replaced this cable on mine when I first bought the car as it had a hot start problem and it turned out to be this very cable doin what I just described.
This true, cos if it is i'm buyin'.
G40 AD
getting 12v across all the earth straps at the chasis end.....
anyone got any clues?
G40 AD
#21
is there any possibility that the relays could be at fault...
Saf said that he had the same trouble when his bat was  kaput...gonna try a new bat tomo...
G40 AD
replaced the battery tonight... still no joy!
gettin really fed up... someone please throw me a lifeline or am i going to have to kill yet another supercharger...
lance
there is 2 plugs under the right hand side (lokin at the bay) of the throttle top hat one is for the starter see if its got a good connection
Puncharado
G40 AD
just to confirm is this the plug at the back right of the TB... just going from memory
or is it the middle plug of the three in the holder where lambada plug sits?!?!
by the ignition switch do you mean by the by the key barrel?
the cd player (run from the ignition) does keep cutting out... loose connection... could this be linked?
thanks v.much for your help guys!
the ignition switch is on the steering column, behind where you put the key in.
Puncharado
#27
Quote from: G40 AD on April 20, 2010, 08:52:42 AM
The white plug actually on the TB is for the throttle open/closed switches so not that one. It's one of the black ones, thick red/black cable and thinner blue cable.
G40 AD
will investigate this eve!!! am i just testing for the obvious poor connections etc or are there any other tests i can do?
cheers,
Ad
G40 AD
no joy with the plug... think it cud be the relays... tried another bat didnt work...
how should i test the ignition? best to just remove the steering wheel cowling and check for any visible faults or perhaps with the car running wiggle the wires and see if it cuts out?!
cheers,
Ad
