Author Topic: Yoof's Turbo  (Read 213304 times)
Yoof's Turbo
« on: December 30, 2008, 11:18:54 pm »
This should really have a home here (more relevant than Club Polo)
My car started as a 1991 Polo GT, seen here:
Didn't start life like that, was probably after 2 years or so, used to run a 90bhp 3f engine and 80bhp of nitrous  ;D
Then, once that got boring a new challenge was set (throttle bodies on a budget- was still 18/19 then!)
Hence:
Once myself & Andy had done the megasquirt it ran well, needed more tweaking but I went turbo instead:
Car before running a low 13sec @ Santa pod:
Note the Subframe peeking through- proper research & development being done!!!!
Polo Show in Sept '08
Made 203bhp & 187lbft without nitrous at 21psi boost- G40 RR Day @ Aldon Automotive
Made 223bhp & 210lbft with nitrous  ;D
Car at Oulton Park late November (more subframe testing):
Which brings me almost up to present, plans are for a refresh/revision on some suspension areas, mainly spring rates, rear ARB rates, rollcage, front dampers, proper adjustable top mounts.
Engine side of things need a new turbo and decent dump valve (going Tial as fed up of blowing Bosch ones apart) then I'm good to go!
2009 Plans are more trackdays, and to run into the 12s at Santa Pod  :-[
Offline polo dan
Re: Yoof's Turbo
« Reply #1 on: December 31, 2008, 02:59:35 am »
yes yoof  seen a couple of the vid`s of you on the track day with mathers n that
you guy`s are really pulling the potetial out of the polos now
go no the 12`s
Offline Alex
  • Hack
Re: Yoof's Turbo
« Reply #2 on: December 31, 2008, 04:56:50 pm »
One of the best around, a real ground breaker!
Offline Dirrt
  • #actlikealadythinklikeadirrt
Re: Yoof's Turbo
« Reply #3 on: January 13, 2009, 03:43:46 pm »
I can't wait to see this 8)
Offline lance
Re: Yoof's Turbo
« Reply #4 on: March 06, 2009, 04:14:28 pm »
you running standard management?
Re: Yoof's Turbo
« Reply #5 on: March 07, 2009, 12:15:08 pm »
Yes- with a few additional components  ;)
Just taken it out and I've come back shaking, last time I drove it was Novemeber 2008. Gets to 140mph quicker than my diesel gets to 70mph... ;D
Few bits to sort out before santa pod still.
I'll get some pics up later.
Offline lance
Re: Yoof's Turbo
« Reply #6 on: March 07, 2009, 02:48:57 pm »
when you taking it to the pod?
do you run a lsd?
Re: Yoof's Turbo
« Reply #7 on: March 08, 2009, 06:41:00 pm »
nice one yoofington, I've not driven mine since the same track day last nov either!  Shouldn't be much longer for mine either.
Re: Yoof's Turbo
« Reply #8 on: March 11, 2009, 08:58:40 am »
Hoping to be there for GTi Festival, still got to swap my rear springs, TIG some bits onto boost pipes, get rid of this old fuel (should be fun  ;D ) and sort the nitrous and general tune of the car out.
I run a gripper plate diff  ;)
Offline lance
Re: Yoof's Turbo
« Reply #9 on: March 11, 2009, 02:43:43 pm »
all sounds cool mate one of the best polos in my eyes.
ill hope mine is ready june time think ill go retro show as i went last year and it was fantastic all different stuff, better than the same old same old at vw shows now.
Re: Yoof's Turbo
« Reply #10 on: March 27, 2009, 10:33:45 pm »
Put some fresh rubber on the compos (hard to get hold of now A539  :( )
Lambda probe is on its way out, I've found a boost leak though, had all the inlet etc off today, had a good freshen up and re ran the whole vacuum system now in gucci pipe  8)
Some pictures from this afternoon, replaced the old tired rad with a new ally one  8)
Getting there, still got to finish it tomorrow, plus set the nitrous up, and take the rear suspension apart...  :D
Offline giorgio
Re: Yoof's Turbo
« Reply #11 on: March 28, 2009, 11:34:04 am »
Sweet update Pete.
Taken a day off today to make a fan bracket for the slim-line.
Tempted by the invitation class of the VAG Trophy?
Re: Yoof's Turbo
« Reply #12 on: March 28, 2009, 12:19:06 pm »
Hmm, would want to see how it works tbh. I've not got a cage and last thing I want is some 'haveago hero' in his 8v GTi running out of talent and running into me.
I am interested in it though, especially if it's free. 1/4mile and trackdays mostly this year for me, possibly a trip over to a certain toll road.
Car is now back together, boost turned down to 20psi (nitrous setting) just got to stick the bottle in, and change my rear springs. Then get pissed with Hayesey  ;D
Offline Alex
  • Hack
Re: Yoof's Turbo
« Reply #13 on: March 28, 2009, 05:53:16 pm »
Awesome, awesome car this! I wish mine was half that clean and shiny!
Offline poloeatonm45
Re: Yoof's Turbo
« Reply #14 on: March 30, 2009, 11:07:52 pm »
can  i ask how much you paid for your alloy rad? my standard one cant seem to keep the temp down with my eaton convertion. are the alloy rads alot better than standard ones ? i,ve heard they are
steven
