This should really have a home here (more relevant than Club Polo)
My car started as a 1991 Polo GT, seen here:
Didn't start life like that, was probably after 2 years or so, used to run a 90bhp 3f engine and 80bhp of nitrous
Then, once that got boring a new challenge was set (throttle bodies on a budget- was still 18/19 then!)
Hence:
Once myself & Andy had done the megasquirt it ran well, needed more tweaking but I went turbo instead:
Car before running a low 13sec @ Santa pod:
Note the Subframe peeking through- proper research & development being done!!!!
Polo Show in Sept '08
Made 203bhp & 187lbft without nitrous at 21psi boost- G40 RR Day @ Aldon Automotive
Made 223bhp & 210lbft with nitrous
Car at Oulton Park late November (more subframe testing):
Which brings me almost up to present, plans are for a refresh/revision on some suspension areas, mainly spring rates, rear ARB rates, rollcage, front dampers, proper adjustable top mounts.
Engine side of things need a new turbo and decent dump valve (going Tial as fed up of blowing Bosch ones apart) then I'm good to go!
2009 Plans are more trackdays, and to run into the 12s at Santa Pod
