Hi Mate,
Thanks for the comments- I ran 203bhp with a K03 turbo at 21psi, used a 250kPa map sensor (which we sell in the traders section) and a decent custom map.
I used a rothe manifold and downpipe connected to one of our 63mm systems, the block is overbored to 1341cc and uses Accralite pistons, although I'd use Wossner ones if I was doing it again (lower compression ratio). I also use aquamist.
The engine is nothing special, it's the refinement, calibration and set-up of everything which takes the time, and makes the most out of everything.
I use 256mm brakes with EBC yellowstuff pads, RBF600 Fluid, and standard Golf 16v Brembo discs. I've used various suspension set-ups over the years, combinations of springs rates, cup car dampers and bilstien motorsport items, I'm currently settling on a G40 cup car kit though, with some additions to the track control arms, and custom top mounts, not forgetting a Polo-PP stage 3 subframe
Hope this helps,
