Daily G40- Windsor Blue L-Reg
Started by Yoof, September 10, 2012, 07:41:25 PM
Etches
z3i
That looks spot on!! this is going to be lovely when finished
z3i
Where did you get the connectors and the white rubber grommet for the blue temp connector? are they used on later polo's?
PeteG40 on here, had about 5 laders done by him (mine and customers) and every one has been spot on- he's cheap too!
P1rik
That's good to no I think mine needs doing got abit of oil coming out of the thottle body.
How much does he charge thanks
Quote from: z3i on February 22, 2013, 08:50:56 PM
Workshop at work- you can buy them from RS Components Farnell etc.
Swapped the oil feeds for some fresh ones I had, and also put the alternator and lader on to check everything fitted since its been painted, tapped the hole out an all the mounts now too, so everything runs in as it should.
Hopefully a mate can bring his crane round tomorrow and I'll drop it in  :)
Engine now bolted in, sorry for the crap pictures, phone was very cold.
Happy with how it looks, another couple of days and it should be running and ready for MOT  ;D Then ready for sale  :(
Justin14100
Please paint that throttle body with the same silver enamel as the rest.
Nah, they look crap if you only paint the top part, and are a pain to re-assemble properly without them sticking.
jez1272gt
Looking wicked that mate. Spot on. Bet you want to keep it really... ;D
Yeah I really do, hence the extras like subframe - but needs must! Mrs has a car and this is car no 4 for me, our new gaff can't accommodate all of them, so this will have to go :(
More bis done, despite the snow today, hopefully should have the last few parts arrive this week, and be ready for MOT soon.
Struts that came with the car had knackered wheel bearings, so put on a good set after putting the konis (adjustable) and springs on, and a lick of paint:
New discs and pagid pads:
RBF 600 fluid
All boost hoses replaced with black silicone & new clips:
New earths:
Front end all done:
Few bits of plumbing, wiring loom and boost pipes still to do:
Grown quite attached to this now  :(
Alex
I'm not surprised. Lovely example!
z3i
Did you change the charger outlet boost pipe to the original intercooler? if so what did you use?
Wouldn't mind seeing this in the flesh before you sell :) though i think you should keep it
Quote from: z3i on March 18, 2013, 07:42:52 PM
Sure whoever buys it will bring it to some shows  :)
I've not found a charger to IC pipe yet (got a wanted ad up) if no one has one I'll replace it with a length of silicone
Cheers for the kind words!
