Currently my Polo Breadbin consists of the following platform (keeping it simple): 1341 bottom, standard valve size ported head, ported g40 inlet manifold, original G40 cam, DTA S40 management, G60 injectors, Golf 1.8 throttle body for TP Switch function.... It's Full blend Lader is giving hideous boost at 1800rpm and is walloping tyres and driveshafts even with a boost/vacuum controller + dump valve setup to dump some boost low down. These Laders seem to take some managing without the original bypass/throttle body.. Anyway I prefer the progressive spool up of turbo setups so I now have my K04 bolted up and am scratching my head at cam choices.. I know big turbos on little motors come with big lag hence why I've kept the G40 inlet manifold/std valve size - I want to keep fast low down airflow to reduce lag. I'm not in the budget for building hybrid turbos so will have to make do with the K04 I found in the parts bin. Some say GT cam with big turbo will spool it up quick and then die at 4500.. I don't know.. Will the G40 cam further exaggerate this?? I hear that n/a cams are best (like GT) I also have on the shelf a 1043cc std cam.. Anyone used one of these...?? It's a minefield! I've probably opened a can of worms now! Would be nice to hear what you lot have to say.. Thanks in advance.
