Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Club G40
Photos and videos
Ongoing Projects
My Polo Gt-g40-g60
« previous
next »
Pages:
1
2
3
4
5
Go Down
Author
Topic: My Polo Gt-g40-g60 (Read 26291 times)
Re: My Polo Gt-g40-g60
Reply #15 on:
April 04, 2012, 09:35:30 pm »
Depends what wide belt kit you get. Some are massive and you get new bigger cogs too. Cost a fortune though.
What you sending it to jabba for?
djtez
aaAAHH CHOOO!
Reply #16 on:
April 04, 2012, 09:42:48 pm »
It has a wide belt on the standard cog atm 11/12mm either or
Is it worth me
Paying the 200 euros for wide cog and 20mm belt.
I was sending the charger to jabba to have it overhauled. Service with new bearings and seals..
Administrators
Housewives heart throb
Reply #17 on:
April 04, 2012, 09:52:14 pm »
i've never heard of an 11mm belt snapping. plus a 20mm wide one will only sit 11-12,mm on the top shaft!
djtez
aaAAHH CHOOO!
Reply #18 on:
April 04, 2012, 10:05:45 pm »
im just chasing the best,
Too many times have a wasted money on doing the cheaper option and something go wrong..
my understanding is the the 20mm belts come complete with two wider cogs to match ..
http://www.rpm-tuning.com/en/g-lader/g60-tuning.htm
Administrators
Reply #19 on:
April 04, 2012, 10:23:08 pm »
they are wider cogs. But the top shaft that the cogs bolt on to isnt any longer if you know what i mean
djtez
aaAAHH CHOOO!
Reply #20 on:
April 04, 2012, 10:25:58 pm »
ah yes, the belt covers the cog but the cog does not fully cover the shaft...
it is there for only bolted on and possibly making more strain on the top shaft bearing ?
Administrators
Reply #21 on:
April 05, 2012, 09:13:54 am »
plus rpm dont answer the phone or emails... so unless you can get elsewhere???
djtez
aaAAHH CHOOO!
Reply #22 on:
April 05, 2012, 09:29:11 am »
Gonna trust your judgement here ..
Ill just replace the 11/12mm belt on it !
Reply #23 on:
April 05, 2012, 11:24:21 am »
That rs outlet, if you run a fmic your best off getting the 165 degree one.
Also the inlet that that they sell, can get cheaper on ebay.
djtez
aaAAHH CHOOO!
Reply #24 on:
April 05, 2012, 12:57:12 pm »
does the g40 inlet collar not fit ? .. meaning are the bolt distances the samE?
coz i have a 80mm+ inlet collar on my R1 ..
Reply #25 on:
April 05, 2012, 08:24:17 pm »
The g60 inlet collars i have seen are to fit hoses that are 90mm. Mine is 76mm and i dont think it will fit.
djtez
aaAAHH CHOOO!
Reply #26 on:
April 06, 2012, 01:08:32 pm »
aw well..
i saw the 90mm on ebay.de !
also max rpm has them!
djtez
aaAAHH CHOOO!
Reply #27 on:
April 07, 2012, 12:30:36 pm »
Basically im looking for advise on the MAP sensor situation ..
im aware of 250 & 300kps
from this information ..
A G40 charger will produce: 566ccm³ per rotation
A G60 charger will produce: 860ccm³ per rotation
860 / 566 = 1.519 (51%) more flow ...
so say for instance my car was to make 14psi on 65mm pulley ..
would that make this 14 x 1.519 = 21.2psi ... (1.463bar) ..
ive seen on most motor-talk.de discussion that g60 chargers making 1.6 bar in the 1300cc ..
should a go up to 300kpa.. are there any downfalls ? .. .
Thank you!
Reply #28 on:
April 07, 2012, 03:43:34 pm »
im running 22 psi with a 250kpa map sensor which is pretty much up to its limit you can run a 300kpa map sensor but you will loose the reseloution on it.Think youd probably get away with a 250kpa but the person mapping your car should have the finial say in this
djtez
aaAAHH CHOOO!
Reply #29 on:
April 07, 2012, 08:53:10 pm »
Dub please explain loose resolution ?
im kinda Sh*tt*n out on using a 65mm pulley atm ..
the more a read the more a get scared !
Pages:
1
2
3
4
5
Go Up
« previous
next »
Club G40 Forum
Club G40
Photos and videos
Ongoing Projects
My Polo Gt-g40-g60
