Hi guys,
There's been quite a bit of progress and this is an update i've been meaning to write for a while. I'm sure i'll miss stuff and gloss over some others, but the most important thing to me, is that it's not far away from a fire-up now (in the grand scheme of things).
My man at work covered my woodwork in the rear for me - being a trimmer by trade, he did a much better job than I could of. It's the same guy who made & fitted my headlining for me. Ledge.
Then I sorted the carpets. Cleaned them up first as i'd just ripped them out 4 years ago! Bit of a job making it fit around the new seat mounts and in fairness not the tidiest of finishes but it's fine - I'm being picky.
I needed to re-visit the seat subframes. Mocked & tacked them up at the time, but they needed refining. They needed seatbelt points welding in for the buckles too.
The passenger seat is fixed, drivers moves forward & back. When I put the seat back in now with the headlining in place, there was just not enough headroom. The same problem I had back in the day with my Mk2f GT. Needed a radical solution. The BMW mini seat-runners are really good as they are so adjustable and narrow too. I needed to loose the height of the mechanism to get the seat down as far as possible. To cut a long story and a lot of frowning short, I lost the mechanism which operates the two runners together, then put swapped the right & left runners round on the subframe. It's worked a treat - I have one tab each side of the seat I press which realises each runner. Lost about 50mm in height too. All good.
So I've got the seats & belts in.
Sticking with the interior, turned my attention to the gearknob with integral switch for changing the boost state, and after that the auxiliary gauges.
So first, I got my pool ball and bought a tap for the random thread pitch! Then used some plywood in my machine vise to stop the ball from being marked, and drilled it out like this:
1) Spent a lot of time lining it up in the vice.
2) Ø5mm pilot right through.
3) switch rebate - Ø19mm wood bit.
4) switch body clearance drill to depth.
5) used 5mm drill to line up ball 180° round in vice.
6) gearstick tapping drill Ø through.
7) tap for gearstick.
fit & admire.
9) brew.
It looks good. When I tighten it up straight, the last quarter turn will cut threads and hold it in place.
The dash is more of an organic shape than I thought. The template I knocked up in ally for the aux gauge pod as symmetrical didn't fit, so got some pizza box cardboard and got busy making a new template...
That fits better. So I made it out of ally (again!) folded it up, cut the holes & got the gauges out for a shufty.
Then got the boys at work to knock me up a faceplate on the router while I painted it black and bonded on some plastic sides to cap it all in....
Gotta have a birra fun eh?!
It took me an age to find out that the Mk1 interior light is in the dash! I couldn't remember and thought I'd missed it out in the headlining. So anyway I took the opportunity to put it in the base of the aux panel. So the LED under the boost gauge tells me when the bleed valve is switched in. The WOT led tells me when the ECU is seeing WOT, which is handy in conjunction with the AFR.
Back under the beast, there are two things which need my attention before the car can be put on the floor. Handbrake cable and exhaust. I'm mating Mk4 golf cables to the original Mk1 polo front cable. I found a NoS front cable on eBay which I fitted, then worked on the rear cable. I've cut the cable sleeves down on both the LH & RH cable. Drilled through & counterbored an M14 bolt for each side to hold the outer sleeves and cut the inner cables down to be joined. I sent the M14 bolts went for re-plating (BZP) so they wont seize. CABLE-TEC joined the cables for me (in fact, they ditched the original inners in favour of one complete new cable the right length with new ends) and I fitted it earlier today. Works a treat and I've got adjustability at three points of the system. Bonus.
Obviously those are pictures of the mock-up so I could get the cable lengths right.
So I'm trying to set myself up for a few days over Christmas. A539 rubber is going on wheels, the bumpers are being pulled back, re-textured and painted matt black in PU, Andy blew me a chip with a 'safe' map which is going in the ECU, and I've pulled the doors, 'gate and bonnet out of storage & I'm building them up too.
Happy days
