Author Topic: Etches G40 (2)  (Read 55565 times)
Offline higgo
Re: Etches G40 (2)
« Reply #105 on: June 03, 2014, 10:31:30 pm »
Bet your gutted but also glad you started the poking...... least now you can stop it before it gets worse. Love this car, makes me actually like my white mk3 as I can imagine its as cool as this (It really isnt!)
Offline JoeH
Re: Etches G40 (2)
« Reply #106 on: June 03, 2014, 10:54:03 pm »
I always tend to fill the sills full of some decent waxoil on any polo's i've had, as holes in sill gets em all eventually, imo.
Hope you get it done.
Offline Etches
  • Still got the G...
Re: Etches G40 (2)
« Reply #107 on: June 04, 2014, 10:14:01 am »
Cheers Higgo, I've only ever owned alpine white mk3s since 2007 haha!
Joe man, only problem with doing that is that if you put waxoil on the inside is that its flammable, dont really fancy another fire at least till next year haha!
Will get some pics up tnite how I get on, not welded before so its guna be some good practise haha!
Offline Etches
Re: Etches G40 (2)
« Reply #108 on: June 05, 2014, 12:19:27 am »
Straight 5 hour stretch tnite!
Marked out danger zones
All the shit cut out
Metal cut
Managed to do two
My appreciation for welders has gone up ten fold, I practised for about half an hour pre welding on the car and managed to find the setting I preferred. Only managed to blow a few holes but sorted em, not pretty but its solid as fuck.
Will get ground back tomorrow undersealed , high build then painted. Should manage to get to bed normal time hopefully!
Offline Etches
Re: Etches G40 (2)
« Reply #109 on: June 05, 2014, 10:15:02 pm »
Yeah , I've not enjoyed this job haha. What a ballache!!
Sorted the final two, the small one was an absolute bastard. Ran out of gas which made it difficult!!
All cleaned and undersealed,
Offline Etches
Re: Etches G40 (2)
« Reply #110 on: June 11, 2014, 06:08:45 pm »
Got the MOT monday , flew through with minors for a little bit of crumpled sill from jacking up and an oil drip.
On the way home to sheff lost all boost, got a massive blow from the turbo manifold-turbo section. Guna whip that off to check , fingers crossed its just the gasket! Polo show next week so best be an easy fix.
Offline Etches
Re: Etches G40 (2)
« Reply #111 on: June 11, 2014, 07:37:18 pm »
Just spent the last half an hour to find this,
The old tubular - cast argument comes to mind lads!! Guna take it somewhere to get welded up properly. Bloody annoying!
Offline z3i
Re: Etches G40 (2)
« Reply #112 on: June 11, 2014, 07:40:47 pm »
Ah Dayum!! Message Phil J lol
Re: Etches G40 (2)
« Reply #113 on: June 11, 2014, 08:46:53 pm »
when i saw the pics all i thought was 'flange' haha
Re: Etches G40 (2)
« Reply #114 on: June 11, 2014, 08:52:57 pm »
Where did you get your oil drain line from please? Looks decent.
Make sure you mark up the exact orientation of the flange in relation to the manifold, don't want to find the downpipe etc. doesn't fit properly after you get it re-welded!
Offline Etches
Re: Etches G40 (2)
« Reply #115 on: June 11, 2014, 10:06:52 pm »
Just looked through 30 pages of Pm's Andy and couldnt find the chap off here who I bought em from! Do you run a gasket on the feed?
Fortunately there is a weld bead which shows the orientation but Ill Sharpie marker it to be sure!
Its lasted 6k miles so not very good at all, fortunately I've just nabbed those poly engine mounts so hopefully that stops the engine moving as much.
Offline z3i
Re: Etches G40 (2)
« Reply #116 on: June 11, 2014, 11:57:06 pm »
Such a child....
Offline Etches
Re: Etches G40 (2)
« Reply #117 on: June 14, 2014, 07:07:21 pm »
Managed to find some lad in Barrow to sort my manifold using a beast of a tig
He did a really good job welding from both sides!
Offline Etches
Re: Etches G40 (2)
« Reply #118 on: June 17, 2014, 08:16:42 pm »
Been a really rushed week as I'm going to the polo show on friday, sorted the manifold
All back together, had a difficulty bolting the turbo to the manifold as the welds had given less room for nuts when fully tight.
Happy I snapped these up last week, higher shore engine mount bushes and powder coated mounts
Hopefully these should minimise the engine rocking.
Also managed to put the driver sill trim back on
Might get round to chucking those mounts on and give it a wash before friday
Re: Etches G40 (2)
« Reply #119 on: June 17, 2014, 09:00:29 pm »
Is drivers one in right looks upside down compared to others
