Current spec sheet with a little missed off thats at home in the pipeline, ps never add stuff up
1992 Mk2f Polo G40 Alpine White
Chassis:
Polo Performance Parts Stage 3 Sub frame including Wishbone conversion, Rose Joints and rear engine mount.
Front Coilover Conversion with TA Technics
Rear Coilovers Raceland with 1” Nylon spacer
Bonrath Camber adjustable Polyurethane top mounts
Powerflex Polybushes Inner and Outer TCA bushes
Custom Rear Strutbrace TIG welded
G40 Steering rack with Damper
G40 239 vented Disc Brakes
Compomotive M05s alloy wheels 14 x 6 et 20 with Falken 195/45/14 tyres
Tuner Hex Wheel bolts
Engine:
Wossner 77mm Forged Pistons (2mm overbore and decked)
Full rebuild including; Mahle bearings, Febi Oil pump, Chain and Crank seals
Head rebuild including; Stem Seals, Cam seal, 3- angle valve cut, pressure test and skim
Newman Turbo 268/268 Camshaft
Clutch – Helix Motorsport Paddle Clutch
G40 ATV Gearbox
K03 Turbo including Custom braided hoses and return feed to sump
Forge Adjustable Actuator
Ported GT Inlet manifold
Pit Stop Developments 51mm G40 Throttle Body
Custom Tubular Turbo Manifold
Turbo downpipe (heat wrapped) leading to a 2.5” stainless 1 box system with custom mounts EUK
SPAL Slim line Fan
Custom Alloy Catch tank
G60 Green injectors with PPP Map #G40008 utilizing 6psi Boost switch (circa 180bhp)
Forge 008p Dump Valve
Custom 420bhp Front Mount Intercooler with blue Silicon 57mm Boost Pipe
Jabba Motorsport Induction Filter
Sytec Racing Fuel Pump
Magnetic Sump Plug
Interior:
Cobra Racing Bucket seats with custom mounts
OMP Harness Mounts
Rally Design Oil Temp, Oil Pressure Gauges
AEM Wideband Air/Fuel Gauge
Tim Turbo Boost Gauge
Factory black roof lining, sun visors, leather gaiter and carpet.
Black GT Door Cards with Audi Window winders.
G40 160 Clocks, Leather Gear Knob and Steering Wheel
Shell/Bodywork:
De-Locked Passenger and Driver handles
H4 OSRAM Night breaker Bulbs
Clear Indicators with Silva Tech bulbs
Badge less Grill and Pressed Metal Plates
Front and Rear Original G40 Badges
Re-painted smoothed wings
G40 rear arches
Mk2 Polo Coupe Front Arches
Re-painted Boot Lid
G40 Rear Lights
Clifford Proximity Alarm with Immobilizer and central FOB locking,
