Author Topic: Cam fitting  (Read 3974 times)
Offline Jezza-7
Cam fitting
« on: October 26, 2010, 09:06:28 pm »
Im fitting my cam next month and then getting a trailer to move it to get a remap.
Any tips for the cam fitting and tappets?
Re: Cam fitting
« Reply #1 on: October 26, 2010, 09:17:39 pm »
Not too hard but a couple of pointers:
Do the cambelt & waterpump too- it's only £30 extra
Repace both cam oil seals (dizzy end too), the camshaft bearing stud/nuts are M7 and require carefull torquing in the correct sequence, you risk either stripping the stud out the head, or breaking them cam if not.
Haynes has the proper sequence to set the piston position, have you got a vernier pulley to fit too?
Plently of oil over the cam/tappets on installation too, if the tappets have been sitting a while, then leave them in oil for abit bucket side up.
Hope this helps,
Offline Jezza-7
Re: Cam fitting
« Reply #2 on: October 27, 2010, 07:17:55 am »
Cheers yoof
The water pump and belt were replaced no more than 2 months ago.
Got a vernier pulley already on.
The tappets have been sat around in the packagind since bought and havent been opened up but might just put them in oil for a while like you said.
I remember in the haynes manual it says about the sequence of how to torque the bolts.
Will get the cam oil seals replaced.
Is it worth getting new M7 bolts?
Do you put the piston to TDC? Havent got my haynes to hand.
Re: Cam fitting
« Reply #3 on: October 27, 2010, 09:47:19 am »
the torque for the cam bearing cap bolts is something daft like 6nm which isn't very tight at all! You'll need a pretty small torque wrench for that so make sure you have one.
Offline Jezza-7
Re: Cam fitting
« Reply #4 on: October 27, 2010, 10:55:06 am »
6nm, thats not alot. Thats like hand tight, or 3 white knuckles as we say at work. Luckily i can use the torque wrenches from work as mine starts at 20nm.
Cheers for all your inputs, much apreciated.
Offline Jezza-7
Re: Cam fitting
« Reply #5 on: October 27, 2010, 11:15:46 am »
As for the oil seals i got
030 103 085A for the pulley end
030 905 224 (round seal) for the distributor
030 905 261 seal for distributor
Yoof, when you said about the dizzy end one, are the above ones (2 of) both best to replace? On vag cat it shows it going on the end of the dizzy and the other just in front.
« Last Edit: October 27, 2010, 11:19:24 am by Jezza-7 »
Re: Cam fitting
« Reply #6 on: October 27, 2010, 11:29:56 am »
I've just ordered both those dizzy seals from VW as I get a slight leak from there at sustained high rpm
Re: Cam fitting
« Reply #7 on: October 27, 2010, 11:35:29 am »
They're very tight for the spec- remember it's got an angle tighten (90' I Think) after the torque!!
Offline Jezza-7
Re: Cam fitting
« Reply #8 on: October 27, 2010, 11:38:14 am »
What do you mean "angle tighten" after the torque?
Re: Cam fitting
« Reply #9 on: October 27, 2010, 11:40:13 am »
not really sure what your point is there yoof. you still need as torque wrench to set it to 6nm whether the angle tighten after is 1deg or 1,000,000deg.
Angle tighten means turn the bolt/nut by what ever angle it says.  So 90deg means turn it quarter of a turn, it's also much more accurate if you have an angle gauge to do this.
Re: Cam fitting
« Reply #10 on: October 27, 2010, 01:01:44 pm »
I'm well aware of that mate  ;)
I was pointing out it is an angle torque too, so isn't just 6Nm. Should give a breakoff on a M7x1.5 off approx 25Nm post angle.
Offline Jezza-7
Re: Cam fitting
« Reply #11 on: October 27, 2010, 01:13:52 pm »
Ok, so does that mean when torqueing up the bolts, in the correct sequence, you don't just fully torque them up, you do them one by one only going 90 degrees untill all are at the correct torque. That makes sense to me as we work similar on our aircraft.
Re: Cam fitting
« Reply #12 on: October 27, 2010, 01:40:46 pm »
no it means do them up to 6nm (or whatever it is, check haynes!!!!) and then go round again turning each one 90deg (again, check haynes, my memory isnt to be relied on!).
Offline Jezza-7
Re: Cam fitting
« Reply #13 on: October 27, 2010, 01:56:06 pm »
Ah I see. Will have a look at it when I have finished work. Thanks for your help.
Re: Cam fitting
« Reply #14 on: October 27, 2010, 02:28:35 pm »
hayesey is referring to cam/rocker cover bolts, yoof referring to the cam cap nuts!
