Author Topic: PSD EATON KIT - What boost pressure does this create?  (Read 10203 times)
Offline youngprodigys
  • G 3URO
Re: PSD EATON KIT - What boost pressure does this create?
« Reply #60 on: June 05, 2010, 11:56:45 pm »
photo please
Offline vwmk3jon
« Reply #61 on: June 06, 2010, 07:20:56 pm »
Not the greatest pic but i'll get another one when it decides to stop raining and brightens up abit.....................
Offline vwmk3jon
« Reply #62 on: June 06, 2010, 07:21:42 pm »
  • G 3URO
« Reply #63 on: June 06, 2010, 08:48:01 pm »
going to need a better photo mate - i simply cant see anything of the bit i want to look at!
Offline vwmk3jon
« Reply #64 on: June 06, 2010, 09:16:37 pm »
Crappy iphone camera ftl :( I'll grab a torch and try again :)
Offline vwmk3jon
« Reply #65 on: June 06, 2010, 09:41:30 pm »
Any better?
  • G 3URO
« Reply #66 on: June 06, 2010, 10:13:14 pm »
so your telling me you just tightened that bolt up until it got tight?
Offline vwmk3jon
« Reply #67 on: June 07, 2010, 07:30:32 pm »
Nah, its nipped up.
  • G 3URO
« Reply #68 on: June 07, 2010, 08:12:58 pm »
NO! i mean - do you do the bolt up until that gap disappears?
Offline vwmk3jon
« Reply #69 on: June 07, 2010, 09:48:19 pm »
no. Belts still on with it like that plus wouldnt it be pulling the charger out of line?
  • G 3URO
« Reply #70 on: June 07, 2010, 10:23:28 pm »
yes doing that bolt up would put the charger on the piss. BUT that bolt has to be tight!!! that's what holds the charger still and stops it moving and vibrating. if you drive round without that bolt tight then no wonder your belts arnt lasting long. I'd expect your pulley to be worn aswell.
I'd make up a plate to remove most of that gap and use the shims I'm sending to you 2moro to get the gap to zero
Offline vwmk3jon
« Reply #71 on: June 07, 2010, 11:05:15 pm »
i'll have a look and see whats laying around at work tomorrow ;)
