Author Topic: PSD EATON KIT - What boost pressure does this create?  (Read 10204 times)
Offline youngprodigys
  • G 3URO
Re: PSD EATON KIT - What boost pressure does this create?
« Reply #30 on: May 27, 2010, 08:56:03 pm »
well im thinking this is going to be 15psi with my eaton cam in it.
need to get this thing moving now as its taking the piss.
so im going to get a SNS eaton chip and see if i can get it through an mot.
ive half thought about chopping it in for a turbo
Offline vwmk3jon
« Reply #31 on: May 27, 2010, 11:08:27 pm »
I thought about ripping all mine out and going turbo but its nearly there.
Anymore info on these sns eaton chips?
Did you get the other ones i sent?
  • G 3URO
« Reply #32 on: May 29, 2010, 09:11:43 am »
nah, I translated a german page where the guy had an eaton and his chip was sns. but a dead end. I got your chips dood :-) going to try them today. fingers crossed.
oh and one more question to the masses. - dug out my PSD Newman cam box and it has "p2" g40 camshaft - I assume this is correct as the eaton one?
Offline G40Poles
« Reply #33 on: May 29, 2010, 12:45:55 pm »
I brought a P2 cam for my eaton set up and was told it was the eaton spec cam. It's hard though to find out though the exact specs of anyhting PSD as you'll probs know. Your car is looking pretty sweet, I should have my eaton set up running soon i've got a psd eaton kit too so I'm too wondering what sort of pressure it will be running etc.
  • G 3URO
« Reply #34 on: May 29, 2010, 02:15:41 pm »
good luck getting a map lol
Offline G40Poles
« Reply #35 on: May 29, 2010, 09:51:58 pm »
 ;) already sorted
  • G 3URO
« Reply #36 on: May 30, 2010, 11:32:56 am »
how did you sort it?
dont matter chap, ive had enough of being a pikey - im sorting a trailer and its going to be done properly on a set of rollers or il never see this car finished. patience ran out
« Last Edit: May 31, 2010, 12:12:16 pm by youngprodigys »
Offline vwmk3jon
« Reply #37 on: May 31, 2010, 09:10:32 pm »
yeah, i'm interested in where you got a chip from too ;)
Offline Andy
« Reply #38 on: May 31, 2010, 09:47:37 pm »
Replied to your PM Kieran.
Offline g40chris
« Reply #39 on: June 01, 2010, 12:49:39 am »
i had mine AWT kit running on 55mm pulley at 1.3-1.4 bar
i had a custom map for it but it went with the car. i left it in the glovebox by accident
Offline giorgio
« Reply #40 on: June 01, 2010, 06:47:32 pm »
mine get a MAP reading of 14psi
  • G 3URO
« Reply #41 on: June 02, 2010, 04:52:40 pm »
thats more like it giorgio:-) happy days!
so mine should be 14-15psi like i initially thought.
praying to god andy will be able to come and have a look at this soon. my fingers are so tightly crossed
Offline giorgio
« Reply #42 on: June 02, 2010, 06:40:08 pm »
your assumptions should be about right. I have a PSD super-wicked-sick flowed head so that explains the pressure drop
Offline g40chris
« Reply #43 on: June 02, 2010, 10:10:57 pm »
mine was running the PSD head aswel
Offline giorgio
« Reply #44 on: June 03, 2010, 06:05:37 am »
Mine is a BVH *willy waving*
20psi seems relatively high. What sort of readings are the turbo boys running?
