PSD EATON KIT - What boost pressure does this create?
Started by youngprodigys, April 14, 2010, 09:28:40 AM
youngprodigys
vwmk3jon
Not the greatest pic but i'll get another one when it decides to stop raining and brightens up abit.....................
youngprodigys
going to need a better photo mate - i simply cant see anything of the bit i want to look at!
vwmk3jon
Crappy iphone camera ftl :( I'll grab a torch and try again :)
vwmk3jon
youngprodigys
so your telling me you just tightened that bolt up until it got tight?
vwmk3jon
youngprodigys
NO! i mean - do you do the bolt up until that gap disappears?
vwmk3jon
no. Belts still on with it like that plus wouldnt it be pulling the charger out of line?
youngprodigys
yes doing that bolt up would put the charger on the piss. BUT that bolt has to be tight!!! that's what holds the charger still and stops it moving and vibrating. if you drive round without that bolt tight then no wonder your belts arnt lasting long. I'd expect your pulley to be worn aswell.
I'd make up a plate to remove most of that gap and use the shims I'm sending to you 2moro to get the gap to zero
vwmk3jon
i'll have a look and see whats laying around at work tomorrow ;)
