Author Topic: PSD EATON KIT - What boost pressure does this create?  (Read 10141 times)
Re: PSD EATON KIT - What boost pressure does this create?
« Reply #45 on: June 03, 2010, 11:14:32 am »
21psi on my rr printout from john sleath, with a slight peak at 21.5 when the turbo spools up and the wastegate opens:
That power plot is at the wheels, was 194 at the flywheel.
« Last Edit: June 03, 2010, 11:16:04 am by hayesey »
Offline dazzle53
« Reply #46 on: June 03, 2010, 12:04:42 pm »
i had mine AWT kit running on 55mm pulley at 1.3-1.4 bar
i had a custom map for it but it went with the car. i left it in the glovebox by accident
ive got that chip  :) but im not running an eaton
Offline vwmk3jon
« Reply #47 on: June 03, 2010, 01:11:51 pm »
Bet its for a 1272 tho ? :(
Offline dazzle53
« Reply #48 on: June 03, 2010, 08:31:17 pm »
it was for a 1308cc
Offline youngprodigys
  • G 3URO
« Reply #49 on: June 03, 2010, 09:38:03 pm »
these Eaton kits have a massive problem trashing belts which i think i found the problem for. this is for you vwmk3jon
the charger doesnt fit flush to the charger bracket, to bolt it up you need to use shims. if you dont the 0.8mm-/+ gap that you pull in when you tighten the bolt up will put the charger pulley out of line and cause big problems for the belt.
heres the photo i said i would post to help you
as you can see thats a large gap! - i found the problem doing a mock up fit on my engine stand.
Offline g40chris
« Reply #50 on: June 03, 2010, 10:20:17 pm »
i stripped 1 belt with the eaton kit. if they run out of line they dont last long. yep that chip was for a lightened and balanced 1308cc bottom end, PSD BVH, PSD eaton cam, aquamist and an eaton charger with 55mm pulley. deffo had 1.4-1.5 bar on the gauge but it was totally different power delivery where the g-lader used to make the boost pressure go straight to 1 bar and eventually drop but the eaton was low pressure to start off and as the rpm increased the boost pressure would keep rising.
Offline vwmk3jon
« Reply #51 on: June 04, 2010, 11:58:17 am »
muchos grasious matey. I see what you were getting at the other day now. I've slightly undone the bottom bolt now to relieve some pressure and hope that it keeps the belt on. Shame i didnt know that the other day when i was in spacer making mode :lol: i'm sure theres roughly a 1cm gap between my charger and the bracket. time to hack up more wheelbrace :ninja:
  • G 3URO
« Reply #52 on: June 04, 2010, 04:32:07 pm »
don't use the car with that bolt undone mate. you need to measure the gap and use the shims I will send you if you pm me your address. 1cm? that seams a lot lol do you mean 1mm?
Offline vwmk3jon
« Reply #53 on: June 04, 2010, 06:53:10 pm »
ive gotta go out in a bit and check things ready for a silly misson tomorrow so i'll measure it. its less than 1cm. guessing 4/5mm but its definately more than 1mm!!!
Offline giorgio
« Reply #54 on: June 04, 2010, 08:04:54 pm »
I am working stupid hours as some retard has become a great fan of binning his car at every GP so have not really got the time/motivation to write an explanation up in full but -
The psd bracket is pretty poor. the charger flexes about far too much.
Take your bonnet off and rev your car, its a scary sight
Offline vwmk3jon
« Reply #55 on: June 04, 2010, 11:27:24 pm »
i can feel it occasionally :(
  • G 3URO
« Reply #56 on: June 05, 2010, 12:04:42 pm »
I agree the bracket could do with some more meat on it as it can flex- but you can take steps to stop this. if you look at your rear bracket giorgio - that ain't going to do fook all to stop it moving! that just holds the charger up at the back. what I have come up with uses the hole which goes right thro the charger under the charger inlet. it bolts solidly to that bracket on the exhaust and it's an important integrale part of holding the charger.
Offline vwmk3jon
« Reply #57 on: June 05, 2010, 06:10:28 pm »
I'll get a pic of the epic gap on mine tomorrow but i can assure you its ALOT more than yours   :(  Must be 3 or 4 threads of a bolt.
  • G 3URO
« Reply #58 on: June 05, 2010, 06:54:40 pm »
so imagine how much out of line that must be getting when youve done the bolt up - no wonder your shagging belts quick
Offline vwmk3jon
« Reply #59 on: June 05, 2010, 11:35:18 pm »
Strangely when i got it there was a 2mm wedge tacked onto the right side of the mount on the charger  ???
