PSD EATON KIT - What boost pressure does this create?
Started by youngprodigys, April 14, 2010, 09:28:40 AM
youngprodigys
well im thinking this is going to be 15psi with my eaton cam in it.
need to get this thing moving now as its taking the piss.
so im going to get a SNS eaton chip and see if i can get it through an mot.
ive half thought about chopping it in for a turbo
vwmk3jon
I thought about ripping all mine out and going turbo but its nearly there.
Anymore info on these sns eaton chips?
Did you get the other ones i sent?
youngprodigys
nah, I translated a german page where the guy had an eaton and his chip was sns. but a dead end. I got your chips dood :-) going to try them today. fingers crossed.
oh and one more question to the masses. - dug out my PSD Newman cam box and it has "p2" g40 camshaft - I assume this is correct as the eaton one?
G40Poles
I brought a P2 cam for my eaton set up and was told it was the eaton spec cam. It's hard though to find out though the exact specs of anyhting PSD as you'll probs know. Your car is looking pretty sweet, I should have my eaton set up running soon i've got a psd eaton kit too so I'm too wondering what sort of pressure it will be running etc.
youngprodigys
youngprodigys
#36
how did you sort it?
dont matter chap, ive had enough of being a pikey - im sorting a trailer and its going to be done properly on a set of rollers or il never see this car finished. patience ran out
vwmk3jon
yeah, i'm interested in where you got a chip from too ;)
Andy
g40chris
i had mine AWT kit running on 55mm pulley at 1.3-1.4 bar
i had a custom map for it but it went with the car. i left it in the glovebox by accident
giorgio
youngprodigys
thats more like it giorgio:-) happy days!
so mine should be 14-15psi like i initially thought.
praying to god andy will be able to come and have a look at this soon. my fingers are so tightly crossed
giorgio
your assumptions should be about right. I have a PSD super-wicked-sick flowed head so that explains the pressure drop
g40chris
giorgio
Mine is a BVH *willy waving*
20psi seems relatively high. What sort of readings are the turbo boys running?
