hardchargin40 I applaud your first reply.
The slag came here to lay it out as I was going back to him saying I've been adviced this, this and this, what do you think? Are they right? Are the not? What's best?
Which I don't see any harm in, as you can't always take what someone on a forum says as the solution or the best one because everyone is different when they do have the right answer. My original post says nothing about cost tbf either? I haven't asked for the cheapset option, i think you should all know by now I'm not tight when it comes to my G! At this moment in time I didn't see why a new engine is needed and that's what I was trying to get from you and then you all just said new engine
I think I should ask for posis and negis next time to each option so no confusion.
I can see the logic and your points and why your suggesting i do it
but you all advice it like I'm mature, have a garage, tinkle with it myself at the weekend, hide under the hood on a sunday to get away from the wife and wait for the roast. I'm probably the not commited enough or frowned upon G40 owner you've ever met, was a dream car off mine to own so I did it! Doesn't mean I have to mechanic it because I own it, but I guess this goes into the women woning cars like this debate and what do they expect.
If i need a new engine, I'll pay for it when it needs it. The plan was to fix this and then start putting by a fund because i well know something is going to happen to it after I fix this. It had a rebuild 30k ago iirc, so ok yes it is suggesting weakness and age with other things but that comes with the history off this G too! It was sat for 3 years off its life because the owner couldn't keep fixing it after it broke everytime he fixed something else! I don't need a spare engine, i 've got nowhere for one haha, do you get what I mean? But i know why you're saying I should have one
and I might even say it after it goes bang again but replacing whats broke now will make it new again and checking pump and injectors, job done. It just sent me off on one and into a pickle because i was then like, why haven't you lot been buying new engines everytime a piston goes etc!?!
At least if you buy another engine and melt that too, the chances are you will still have 4 good pistons in total.
Thanks for that
