Afternoon Gentleman
OK so I've melted a piston on the G
and the head has completely eroded away and needs welding and mending… 2 plugs are absolutely fubared like they’ve been raped
Just to re cap, I changed the sparks back to one pins and provided it with a new lambda and blue sensor, this was then running sweeter than ever before, 3 hours later… Oil spat out the dipstick!
It has definitely been under fuelling and running lean. I need to double check the history when I get home to find out what exactly was rebuilt at 113k
What causes am I looking at here?
Weak fuel pumps and dodgy injectors?
Could you tell me please what the standard size of a piston is? Sorry, I did try the search button with fail - 75.485mm?
Is there anything else you know off, what we can try, look for and investigate?
All help, thoughts, personal experiences and opinions muchly appreciated as always.
Thank you
Laura
