Author Topic: Yoof's Turbo  (Read 212954 times)
Offline newt
Re: Yoof's Turbo
« Reply #105 on: November 17, 2010, 07:45:01 pm »
that tank is dented on the top?
i ve seen that before but worse seen one tank that bascally collapsed itself
Re: Yoof's Turbo
« Reply #106 on: November 17, 2010, 09:01:34 pm »
Yup- but not enough to warrant a new one!
Offline Justin14100
Re: Yoof's Turbo
« Reply #107 on: November 18, 2010, 03:20:29 pm »
Diffuser to arrive? I like the sound of that!
Offline Etches
  • Still got the G...
Re: Yoof's Turbo
« Reply #108 on: November 18, 2010, 03:36:07 pm »
Making me think of the bonkers defuser on that copper mk1 polo g40 turbo. Well looking forward to this
Re: Yoof's Turbo
« Reply #109 on: November 18, 2010, 04:07:24 pm »
It's along the same lines, but should intergrate into the bumper alot more cleanly.
Am currently working on a few steering mods which should make it alot better!
Offline dub-disaster
Re: Yoof's Turbo
« Reply #110 on: November 18, 2010, 09:55:57 pm »
Can't wait too see this car done it's going to be an animal !!
Re: Yoof's Turbo
« Reply #111 on: December 06, 2010, 05:21:57 pm »
Not far off bolting stuff back on now, floorpan:
Rebuilt rear axle:
Built up with wheel studs:
All suspension/steering components have been stripped down and POR-15'd:
Now Andy & myself have fully adjustable suspension, it seemed stupid to continue to pay through the nose for tracking places, so I've bought these:
4-Wheel alignment, will do Toe, Camber, Castor, KPI and Wheel Runout, should be worth its weight in gold whilst setting mine up, I'm keen to get the rear axle spot on too.
Offline lance
Re: Yoof's Turbo
« Reply #112 on: December 06, 2010, 08:44:13 pm »
lookin good mate. anychance you'll share all your set up measurements once you're finished? ;)
Re: Yoof's Turbo
« Reply #113 on: December 06, 2010, 11:02:39 pm »
Aye for sure, although not sure everyone will be able to achieve them, I've got adjustable bottom arms, stage 3 frame, and adjustable top mounts, so a fair amount of wood to get lost amongst the trees in  ;D
Also I'll be running cut slicks with camber to suit the track too- not sure you'd want this on the road!
Offline xandyx
Re: Yoof's Turbo
« Reply #114 on: December 07, 2010, 01:19:15 am »
i want to clean/paint underneath my car to avoid rust. what kind of paint and brand of paint did you use?
thanks
andré
Re: Yoof's Turbo
« Reply #115 on: December 12, 2010, 09:36:29 am »
Andre- all rust was cleaned first, then I used Vactan, then primer, then POR-15 or underseal. The front wings are Por-15 metal ready, then Por-15 black.
Flat floor welded in  :)
Re: Yoof's Turbo
« Reply #116 on: December 20, 2010, 10:36:04 pm »
Spent this afternoon mocking up the diffuser- fuel tank and rear axle installed (but will need to remove them again for the final bit of welding).
Diffuser needs to be higher at the rear, which is tomorrow's job hopefully- then I can cut my proper bumper and make a neat job of everything.
Will need a new exhaust as the old backbox doesn't fit.
Excuse the iPhone pics:
Point of view from air underneath the car:
Side profile (rear needs to be raised):
DTM Polo:
Doesn't stick out that much:
Currently there's about 1" between the diffuser and rear axle- Ideally this gap is as small as possible:
Will be making a Mk2 diffuser from ally at some point anyway, so not going to worry too much right now.
Offline polo classic
Re: Yoof's Turbo
« Reply #117 on: December 21, 2010, 02:12:10 pm »
Where did you get the diffuser`?
Re: Yoof's Turbo
« Reply #118 on: December 21, 2010, 06:19:16 pm »
Polo PP  :) - Chap who makes the subframes knocked it up for me. Was made on a squareback so I've done some mods today to get it sitting higher.
This is Mk1 made from steel (about 4kg) but I'd like one from ally next.
Re: Yoof's Turbo
« Reply #119 on: December 23, 2010, 01:22:02 pm »
Finished tewaking the diffuser, now sits alot higher and fits nicely into the bumper (still got mock up bumper on in these pics):
Rear is vactanned and stone chipped now:
And the boot floor is primered ready for paint:
