PSD EATON KIT - What boost pressure does this create?
Started by youngprodigys, April 14, 2010, 09:28:40 AM
youngprodigys
Hiya guys
as in the title really, cant ask the man who designed this as he got kidnapped by martians or some other reason for his disappearance.
I need to know what boost this setup makes?
im guessing its the 15psi the map sensor could cope with- but have a feeling it may be more. obviously im only appealing to about 6 others who have this setup as there rocking horse sh1t
if you are having it mapped - i'd put a big map sensor in just incase
doesn't seem to make much sense to me to not go for more than 1 bar, otherwise why bother with the eaton at all?  It's going to depend what size pulley you have, imagine beavis used various ones depending on what the person wanted at the time.
youngprodigys
why go for the eaton? ermmm it looked good :-S as silly as that answer is it's the truth.
iv got photos of 2 kits and I have mine and the pulleys are all the same size hayesey. i just ordered the kit - there was no options or anything like that.
just heard back from giorgio he is running a BVH and it's 11psi on the gauge. it's got to be a bar!
youngprodigys
BUMP
ANyone want to shed some light on these kits? or does anyone have a chip with a map on?
lance
i made my own kit and it ran well over a bar i know that dosent help much though.
youngprodigys
i had my old AWT kit running over 1bar - but i just cant guess or my engine will go bang.
Shows what happens when you put trust in a company and get shafted
best bet is to measure the crank pulley and the charger pulley and see if the sizes (or at least the charger rpm/engine rpm) are the same as anyone else with an eaton kit fitted.  Or at least this will tell you if yours will make more or less boost than Lance's or whoever else can post up their measurements.
youngprodigys
#8
well my crank i believe is a standard PSD toothie 1. it has 53 teeth. and the charger pulley has 24 teeth.
i have just been in touch with "LregG" and he says his was running 19psi with a 51mm throttle.
i have just gone over some old photos and he has 24 teeth on his charger pulley by the looks of it.
i have asked him for a couple of photos to confirm this.
EDIT! - just found this on Club polo - someone called milgo was selling it
its the same - after painstakingly counting them sodding teeth - 53 & 24
vwmk3jon
youngprodigys
Quote from: vwmk3jon on April 20, 2010, 09:05:59 PM
I have LregG's old eaton kit ;)
WHAT CHIP!!!! mate - the whole reason im trying to find this out is because i cannot find any information on the map/ spec etc etc
PM'ing you now mate
polo classic
Just get it custom mapped with G60 injectors and see how it goes
youngprodigys
poloeatonm45
i have a home brew eaton kit with a psd toothed supercharger pully and it runs around 19-20 psi with a 51mm throttle body.
