Author Topic: Plastic shield under oil cap...  (Read 1228 times)
Offline AdzCM
« on: April 15, 2013, 07:40:35 pm »
Rocker cover gasket was leaking something awful. So whipped it off and sorted it all out with gasket sealant etc...
Problem is, like an idiot, I forgot to put the wee plastic shield back in that sits under the oil filler cap. Is this really needed? Only thing I can think its for, is to stop oil hitting you in the face if you remove the oil cap when the engine is running [for whatever reason]....
Ill fit it back again when I do the next gasket change if Its not that important.
Adrian
Offline Robin
  • 194bhp - 1341 Turbo
Re: Plastic shield under oil cap...
« Reply #1 on: April 15, 2013, 08:03:41 pm »
Not needed.
Offline AdzCM
« Reply #2 on: April 15, 2013, 08:27:52 pm »
Cheers buddy..
Offline youngprodigys
  • G 3URO
« Reply #3 on: April 16, 2013, 12:50:40 pm »
just remember you have not put it on. i quite frequently pull my oil cap off when its running and give it a check and a smell.
you will certainly remind yourself if you get hot oil on you.
