Author Topic: Paddle clutches and pedal boxes  (Read 6869 times)
Offline Etches
  • Still got the G...
Re: Paddle clutches and pedal boxes
« Reply #15 on: March 25, 2013, 05:07:19 pm »
Any pics dude?
Offline Jezza-7
« Reply #16 on: March 29, 2013, 10:41:28 am »
What pedal type did you use for the clutch?
Offline youngprodigys
  • G 3URO
« Reply #17 on: April 04, 2013, 11:30:10 pm »
Offline Etches
« Reply #18 on: April 05, 2013, 09:08:20 am »
Looks really smart that Kiz , is the cylinder off a corsa B?
  • G 3URO
« Reply #19 on: April 05, 2013, 04:21:10 pm »
its from an MGF
Offline Jezza-7
« Reply #20 on: April 05, 2013, 08:11:10 pm »
What clutch pedal did you use?
  • G 3URO
« Reply #21 on: April 05, 2013, 08:35:16 pm »
I have a floor mounted bias pedal box mate.
i did before use a modified G40 pedal box with a Passat master cylinder on it. i have an experiment going on with a modified pedalbox which fits onto the 86c chassis with a reverse mounted girling master cylinder - but im to busy with a 1000 other things to work on something i dont need at the minute
Offline Jezza-7
« Reply #22 on: April 05, 2013, 09:51:54 pm »
Kool, will have a look at floor mounted setups as this would be something i would like to do.
  • G 3URO
« Reply #23 on: April 06, 2013, 10:12:42 am »
it wasnt easy to make it fit! you dont get much space and unless you want to sit quite far back its a bugger to fit.
im going through my garage today so as i unearth all the parts i photo them and post them up
« Reply #24 on: April 06, 2013, 02:47:58 pm »
Marshall modified the original pedal box to take a clutch master cylinder, but ended up hacking it apart and rebuilding most of it to his own design eventually.
This is on my to-do list at some point.
Offline z3i
« Reply #25 on: April 06, 2013, 06:56:09 pm »
My new release bearing is fudged already after 5k miles, must have been from driving around with a fucked pedal box for 1000miles
will definitely be going hydro with a floor mounted pedal box
Offline Etches
« Reply #26 on: April 29, 2014, 07:35:39 pm »
BUMP Taylor man you got any info on the stitch welding on the pedal box? I've just got another one in decent nick but thought it would be a good idea to help it out :)
Offline z3i
« Reply #27 on: April 29, 2014, 08:25:57 pm »
Wouldn't even bother dude, the stitch welded one I got from here broke in Switzerland :( not even worth doing, it broke where the pedal pivots are moubted to the flat metal, a different place from my last one, these boxes are seriously flawed, save yourself the ball ache mate
