Advise from G60 polo people
Started by Jezza-7, February 29, 2012, 09:47:58 PM
Im after all the people on here for some advise on the G60 charger on the G40.
I know eppo (eppofreak?) had a friend, (as i have seen the videos on youtube  8) ) who has done it but are there many people from uk that have done it?
Please get in touch.
Many thanks
James
xandyx
there are a few guys here in Portugal running g60's.
there's a mechanic known as madmike in north of Portugal who has a beast g60, you can see his car on eppo's youtube page.
i can look for his email and you can talk with him.
Ah that his name. I remember now! Yeah seen them videos and sound awesome. Would like to know some info so if you could get his email and he doesnt mind that would be great!
xandyx
eppo's will be in touch with you in a while with details.
cheers!
eppo
#4
Hi James!! The videos i have on youtube, there are of two diferent polo´s G60, but they are made by the same person,.. madmike!!!
If you want to know something more about then, please do a registration in our comunity, me and madmike are the site administrators of the club, here is the link:
http://g-lader.portugueseforum.com.pt/
greetings of Portugal  ;)
Justin14100
What's needed:
Adapter plate,
New pulleys or use a spacer on your ones, (you'd probably want a larger pulley than you use now.)
New pipework,
Bigger intercooler,
MAP sensor + map
Big balls.
Check german ebay for an adapter but there is one here that has a tensioner which would be better than the ones on germany ebay:
http://www.maxrpm.de/G60-bracket-for-VW-Polo-G40-with-tensioner-pulley
Justin14100
Oh, and it would probably want a rebuild with those High RPM bearings, but we dont really know how long they last though.
i'll chase my supplier for the high rpm bearings again.
can use zz shielded bearings (not rubber sealed) which are much higher rpm. However someone on dubforce said that as they are only shields and not seals, his started whinning and needed changing every 1,000 miles!
eppo
Justin14100
I think these special high RPM bearings had viton seals on them - I heard those metal ones end up loosing all their grease quick.
That G60 looks very complicated, no boost return is the boost controlled via a dump valve? What sort of power is that running?
eppo
#10
hi Justin!! thanks for you join us at G-Lader Club :)
you can ask madmike in the forum, here is the link for you can see his project:
http://g-lader.portugueseforum.com.pt/t239-o-meu-projecto-mais-antigo
This is my list so far:
G60 charger
G60 mounting plate for G40
G60 outlet elbow
Induction kit/pipework
FMIC & Pipework
1.5 bar map sensor
5pk 68mm ribbed belt kit
Sytec 135 ltr/hour
Sytec fuel filter
Stainless braided fuel lines
Sytec hose finishers
Bigger injectors? 310cc
Have joined your club as well eppo!
65mm, you know it makes sense....
Regarding FMIC- mine's a custom one, so not much help, however I do have one from my Emtech turbo kit I'm not using, core is plenty thick and it's for big power turbo applications, so should be mroe than adequate for this  :)
eppo
QuoteHave joined your club as well eppo!
You can now have acess to the full forum Jezza-7  ;)
djtez
im pretty much in the exact same boat..
been weighing up the pro's and con's...
but ive decided to keep my ibiza for the rest of the year and polo for summer..
I will have 2x superchargers up for sale.
1 standard with roughly 10k on it
the other is the r1 charger a bought from 'yoof' a while back which has done exactly the run in miles which it was sold at.
