Author Topic: G40 idling problems  (Read 6670 times)
Offline sohailG40
G40 idling problems
« on: October 25, 2008, 09:07:11 pm »
Right where do i start.
Whilst driving along my G40 decided to cut out on me, it struggled to restart but finally when it did she wouldnt hold idle.
After giving her another attempt she adled for around 30seconds and decided to cut out again.
I am stumped & don't know what to do as the G40 was running fine without skipping a beat.
Where do i start & what do i check?
Has anyone suffered the same symptoms?
Thanks in advance.
Offline sohailG40
Re: G40 idling problems
« Reply #1 on: October 25, 2008, 10:32:08 pm »
plz guys help is needed thanks
Offline G-spot
« Reply #2 on: October 26, 2008, 11:20:31 am »
First things first, are you getting fuel pressure?
Then I'd start checking ignition components; starting with earth straps, leads, plugs, distributor, coil, and of course all associated connectors etc
Then move onto idle adjustment settings, though if its suddenly stopped working then its more likely to be a component failure so there'll be no need to check anything in this area.
Once started does or can the engine rev at all?
Offline sohailG40
« Reply #3 on: October 26, 2008, 12:29:23 pm »
Thanks for your reply.
Once the car starts up with the throtle open she revs fine, although when you release the throtle it will cut out and wont hold idle.
Offline sohailG40
« Reply #4 on: October 27, 2008, 06:53:29 pm »
hi yeh ive checked that the car has fuel pressure thats ok
did all the earth leads to the engine and chassis
checked dizzy cap and rotar arm all seems ok saparking ok
but it has got better and now dose hold idel till it get worm and the fan kicks in
then it just keeps cutting out i think it might be a a doggy fuel pump so i am gonna replace the relay tomarrow and see wot it dose.
thanks
« Reply #5 on: October 27, 2008, 07:16:25 pm »
check the alternator voltage too - if its low if might cause issues and obviously if booted will generate more leccy.
Offline sohailG40
« Reply #6 on: October 28, 2008, 12:00:32 am »
i have checked the alternater and it is running at 13. someting volts i thinks thats ok do u ?
Offline sohailG40
« Reply #7 on: October 28, 2008, 08:44:32 pm »
bump
Offline Phil
« Reply #8 on: October 29, 2008, 07:23:47 pm »
Blue temp sender can cause stalling..
Offline sohailG40
« Reply #9 on: October 29, 2008, 10:44:55 pm »
funny enough talking about that blue temp sensor
ive just replace that today its made has made it a bit better when im driving but when at a stop the car still cut out once or twice much better than before tho
could it be the fuel fillter coz that is one part which i have not changed yet?
thank you for your reply
« Reply #10 on: October 30, 2008, 09:00:33 am »
can;t hurt - i think fuel filters should be replaced about evey 60k from memory
Offline sohailG40
« Reply #11 on: October 30, 2008, 09:47:48 pm »
hey guys guess wot i was doing my fuel filter to day
and i found out that the rubber hoes that cums of the fule pump in to the filter had the tinyest pin prik in it
i have changed the fuel filter and fuel pipe and i will test it tomarrow so fingers crossed hopefuly that will sort my problem
i will let you guys no how it went
thanks  ;D
Offline sohailG40
« Reply #12 on: October 31, 2008, 11:10:48 pm »
at last the car is once wot it used 2 b  ;D
no more stalling and cutting out whilst driving
thank you guys for all your replys they were very useful
« Reply #13 on: November 01, 2008, 08:00:35 am »
nice to see its fixed....
now get it to the rr day and see what its pushing out  ;D
Offline sohailG40
« Reply #14 on: November 01, 2008, 10:09:43 pm »
were is the rr day held and wot day ?
