G40 idling problems
Started by sohailG40, October 25, 2008, 09:07:11 PM
sohailG40
Right where do i start.
Whilst driving along my G40 decided to cut out on me, it struggled to restart but finally when it did she wouldnt hold idle.
After giving her another attempt she adled for around 30seconds and decided to cut out again.
I am stumped & don't know what to do as the G40 was running fine without skipping a beat.
Where do i start & what do i check?
Has anyone suffered the same symptoms?
Thanks in advance.
sohailG40
plz guys help is needed thanks
G-spot
First things first, are you getting fuel pressure?
Then I'd start checking ignition components; starting with earth straps, leads, plugs, distributor, coil, and of course all associated connectors etc
Then move onto idle adjustment settings, though if its suddenly stopped working then its more likely to be a component failure so there'll be no need to check anything in this area.
Once started does or can the engine rev at all?
sohailG40
Quote from: G-spot on October 26, 2008, 11:20:31 AM
Thanks for your reply.
Once the car starts up with the throtle open she revs fine, although when you release the throtle it will cut out and wont hold idle.
sohailG40
hi yeh ive checked that the car has fuel pressure thats ok
did all the earth leads to the engine and chassis
checked dizzy cap and rotar arm all seems ok saparking ok
but it has got better and now dose hold idel till it get worm and the fan kicks in
then it just keeps cutting out i think it might be a a doggy fuel pump so i am gonna replace the relay tomarrow and see wot it dose.
thanks
check the alternator voltage too - if its low if might cause issues and obviously if booted will generate more leccy.
sohailG40
i have checked the alternater and it is running at 13. someting volts i thinks thats ok do u ?
Phil
Blue temp sender can cause stalling..
sohailG40
funny enough talking about that blue temp sensor
ive just replace that today its made has made it a bit better when im driving but when at a stop the car still cut out once or twice much better than before tho
could it be the fuel fillter coz that is one part which i have not changed yet?
thank you for your reply
can;t hurt - i think fuel filters should be replaced about evey 60k from memory
sohailG40
hey guys guess wot i was doing my fuel filter to day
and i found out that the rubber hoes that cums of the fule pump in to the filter had the tinyest pin prik in it
i have changed the fuel filter and fuel pipe and i will test it tomarrow so fingers crossed hopefuly that will sort my problem
i will let you guys no how it went
thanks  ;D
sohailG40
at last the car is once wot it used 2 b  ;D
no more stalling and cutting out whilst driving
thank you guys for all your replys they were very useful
nice to see its fixed....
now get it to the rr day and see what its pushing out  ;D
sohailG40
were is the rr day held and wot day ?
