Author Topic: schrink cam  (Read 5633 times)
Offline cheddarcheese
  • i like boobs!
    • supercharged
schrink cam
« on: May 12, 2011, 02:22:49 am »
would a normal schrink g40 cam be any good for a turbo setup?
Re: schrink cam
« Reply #1 on: May 12, 2011, 07:17:04 am »
most people use 268/268s so yes
or i think chris heys uses a 254/254 (i think both sets of number sright but its early!
  • i like boobs!
    • supercharged
Re: schrink cam
« Reply #2 on: May 12, 2011, 01:49:59 pm »
i think its the 152/276 would that be an issue?
Re: schrink cam
« Reply #3 on: May 12, 2011, 01:51:11 pm »
not going to be suitable for a turbo
  • i like boobs!
    • supercharged
Re: schrink cam
« Reply #4 on: May 12, 2011, 02:45:53 pm »
ok cheers
Offline grungeisdead
Re: schrink cam
« Reply #5 on: August 09, 2011, 04:41:27 pm »
anyone had any experience with 272 newman cams with turbo apps?
Power Band 3000-7500
Duration (In/Ex) 272 / 272
Valve Lift (In/Ex) 0.420 10.66 / 0.420 10.66
Cam Lift (In/Ex)0.420 10.66 / 0.420 10.66
Timing (Open/Close) 26-66 / 66-26
Full Lift (In ATDC) 110
Lift @ TDC with Clearance (Inlet) 0.063" / 1.60mm
« Last Edit: August 09, 2011, 04:46:54 pm by grungeisdead »
Offline Andy
Re: schrink cam
« Reply #6 on: August 09, 2011, 05:19:00 pm »
Not directly, no. Probably a bit too peaky to use with a T25 - what size/trim is yours?
Re: schrink cam
« Reply #7 on: August 09, 2011, 05:23:40 pm »
not entirely sure Andy! I've got a couple of pictures, not sure if they are any use to you!
Offline timmitime
Re: schrink cam
« Reply #8 on: December 12, 2011, 07:44:41 pm »
I'm running a newman, schrick turbo copy cam  in my 1.6 turbo £150 new from them  ;D
Offline dub-disaster
Re: schrink cam
« Reply #9 on: December 12, 2011, 07:48:38 pm »
doesnt a gt cam work nicley with a t25 as tommo proved ??
Re: schrink cam
« Reply #10 on: December 12, 2011, 11:25:51 pm »
its running a GT cam atm, but want to get a lairier cam prior to getting it mapped up, save shelling about another 300 quid for a map down the line! but i only plan on running circa 180bhp, not interested in more.
Andy suggested that the GT cam should be more than sufficient for that, so I reckon I will just leave it as is. Will be fitting the 256mm brakes mid-week and will give the car a good drive after that and report back on the characteristics :)
