Author Topic: adjustable pressure switches, no longer available  (Read 7987 times)
Offline DKnight
« on: February 19, 2011, 06:12:35 pm »
was looking for the correct pressure switch and found 2 supplies both who say they are no longer available
anyone know of anywhere else? JBS no longer do them and neither do aquamist
http://www.jbsautodesigns.co.uk/product/3826/adjustable-pressure-switch-022-bar-current-05a-max?utm_source=googlebase&utm_medium=cpc
any alternatives?
cheers
Offline dub-disaster
Re: adjustable pressure switches, no longer available
« Reply #1 on: February 19, 2011, 07:01:03 pm »
I got mine from eBay
Offline cheys03
« Reply #2 on: February 19, 2011, 07:10:04 pm »
Got mine from www.pvl.co.uk about October time. Came with a 1/4 BSP fitting though. Not disastrous mind
Offline DKnight
« Reply #3 on: February 19, 2011, 08:09:16 pm »
you got a link to the ebay one? i searched and searched but could not find the right one
god damn noob i am lol
Offline cheys03
« Reply #4 on: February 19, 2011, 08:33:26 pm »
The last time I looked on eBay the chap could only supply ones with a normally closed contact. Shame as they were a few quid cheaper.
Offline cheys03
« Reply #5 on: February 20, 2011, 12:08:20 pm »
http://cgi.ebay.co.uk/Stainless-Steel-adjustable-pressure-switch-15-2-bar-/150559095626?pt=LH_DefaultDomain_3&hash=item230e057b4a
Searched for 'adjustable pressure switch'. But it's the same chap who can only get normally closed contact switches.
Offline vwmk3jon
« Reply #6 on: February 20, 2011, 11:31:44 pm »
How they wire in? Only thing i havent looked at yet :o
Offline cheys03
« Reply #7 on: February 20, 2011, 11:34:18 pm »
Wire in place of your full throttle switch on the TB. Have a search, there are some smart ideas of how to mount the switch.
Edit: http://www.polog40.co.uk/forum/index.php/topic,2800.0.html
Offline DKnight
« Reply #8 on: February 22, 2011, 11:42:41 am »
well i have been told by 2 companies now that they no longer sell them, what to doooooo
Offline cheys03
« Reply #9 on: February 22, 2011, 12:39:00 pm »
Do those two companies include www.pvl.co.uk ?
« Reply #10 on: February 22, 2011, 01:32:38 pm »
no I think he's been told by ERL and someone who buys them from ERL.
I MSN'd Dan this link:
http://www.epvl.co.uk/pressure_switches/pmn_pressure_switch.html
Although I notice it does say stock "on order".... but that doesn't suggest they're obsolete.
Offline vwmk3jon
« Reply #11 on: February 24, 2011, 12:51:52 pm »
So what's the difference between the pressure switch and an adjustable boost switch to go on the dash? I've got both and just wondering which to use?
« Reply #12 on: February 24, 2011, 01:56:44 pm »
not really sure what you mean by an adjustable boost switch to go on the dash, what is it?  Is it a wastegate bleed valve?  If so then two different things for two different jobs.
The switch we're talking about replaces the full-throttle switch to put the ECU into on-boost fuel enrichment mode.
« Reply #13 on: February 24, 2011, 02:49:25 pm »
You could always use a nc pressure switch and then feed a realy and use that for the no switch
« Reply #14 on: February 24, 2011, 02:59:57 pm »
can do but why add unnecessary complications and more things to go wrong.  just use the correct thing in the first place.  Even if PVL cant supply that one you'll be able to get an adjustable pressure switch from somewhere
