adjustable pressure switches, no longer available
Started by DKnight, February 19, 2011, 06:12:35 PM
DKnight
was looking for the correct pressure switch and found 2 supplies both who say they are no longer available
anyone know of anywhere else? JBS no longer do them and neither do aquamist
http://www.jbsautodesigns.co.uk/product/3826/adjustable-pressure-switch-022-bar-current-05a-max?utm_source=googlebase&utm_medium=cpc
any alternatives?
cheys03
Got mine from www.pvl.co.uk about October time. Came with a 1/4 BSP fitting though. Not disastrous mind
DKnight
you got a link to the ebay one? i searched and searched but could not find the right one
god damn noob i am lol
cheys03
The last time I looked on eBay the chap could only supply ones with a normally closed contact. Shame as they were a few quid cheaper.
cheys03
vwmk3jon
How they wire in? Only thing i havent looked at yet :o
cheys03
Wire in place of your full throttle switch on the TB. Have a search, there are some smart ideas of how to mount the switch.
Edit: http://www.polog40.co.uk/forum/index.php/topic,2800.0.html
DKnight
well i have been told by 2 companies now that they no longer sell them, what to doooooo
no I think he's been told by ERL and someone who buys them from ERL.
I MSN'd Dan this link:
http://www.epvl.co.uk/pressure_switches/pmn_pressure_switch.html
Although I notice it does say stock "on order".... but that doesn't suggest they're obsolete.
vwmk3jon
So what's the difference between the pressure switch and an adjustable boost switch to go on the dash? I've got both and just wondering which to use?
not really sure what you mean by an adjustable boost switch to go on the dash, what is it?  Is it a wastegate bleed valve?  If so then two different things for two different jobs.
The switch we're talking about replaces the full-throttle switch to put the ECU into on-boost fuel enrichment mode.
dub-disaster
You could always use a nc pressure switch and then feed a realy and use that for the no switch
can do but why add unnecessary complications and more things to go wrong.  just use the correct thing in the first place.  Even if PVL cant supply that one you'll be able to get an adjustable pressure switch from somewhere
