Word of warning
Started by Yoof, October 17, 2010, 08:57:51 PM
Evening Gents,
Just a little heads up of a little known problem that can turn into a royal pain in the arse!
Behind the driver's side rear doorcard is a metal pipe- the fuel filler neck breather runs along this and to the lift pump.
Unfortunately when this rusts, it drops onto the inner sill, you can squeeze your hand down and pick up the rusted chunks of pipe.
I'd have a check asap, as mine had made the inner sill start to rust, as such I've now got to cut the whole area out and plate it.
Hopefully you can catch it in time!
DKnight
seen this happen on 3 cars i have scrapped!
worth checking for the sake of popping the door card off
lets all go and check and post pictures, yes yes.
xrrich
I had to do this a month ago, nasty job
G-fortified
Yup ! Same on mine ! The metal tube has just about gone. Using one of those telescopic magnet tools can also help getting the little bits out.
Regards Rob  ;)
Petrified
What is the best action to take if the metal pipe has started to rust but not completely shafted yet?
James- I'd try to remove any fallen rusty debris, and then use a rust eater on it.
The pipe inside is a plastic vent line, so won't be affected by the rusty outer pipe.
Mine was so crusty I just pulled it out  :o But you'd not be able to cut it out easily...
Raw
So is it the rust debris that encourages the rust in the inner wing, or is it that it allows water to get caught in there?
Turbodaily
Majority of my metal pipe is awol, lol. had to replace the (bodged) breather pipe not long ago and noticed it wasnt there! someone must have removed it when they lashed it up the last time. Ill have to fish the crusty bits out with a magnet then!
Quote from: Raw on October 18, 2010, 06:50:55 PM
Encourages it, I don't see the point of the metal pipe- my guess is to pass crash regs...
kayl0rz- Sorry, Gents and kayl0rz  :D
Petrified
Hope this helps.
A shot with the rear door card removed.
Looving down from above you can specs of rust but luckily nothing major yet.
youngprodigys
strange! i was looking at this not long ago as i was refitting my tank (think what a shit way to route a pipe) and mines mint! but i do remember around my pipe at the top was caked in shit - so it must have kept the bad stuff out
vwmk3jon
Had a quick look when i whipped the cards off but not really in too much detail.
lance
looked at mine, was fine but vactan and zinc primer treated it all anyway. cheers for the heads up.
mark_crox
Yep mine fell apart in my hand
Need to work out how to replace it..  ???
