Changed fuel tank - Now cutting out
Started by xrrich, August 31, 2010, 06:11:35 PM
xrrich
Hi guys, i changed the fuel tank as it was leaking, i have put the new one in today connected all lines back.
Then i come to start it , it starts fine, but after that it cuts out after 30 seconds or so.
like it cant get anymore fuel
i havent taken it for a drive yet, but was wondering if anybody can help?
Justin14100
have you filled it up?  :D
check you plugged the fuel pickup back in under the seat
DKnight
yeah it sounds like something is not attached somewhere, does it always run for 30 seconds, or just once then dead?
the 2 pipes off the lift pump may be the wrong way around?
DKnight
this thread picture may be of some use to you, ignore my art attack colouring in
http://www.polog40.co.uk/forum/index.php/topic,5319.0.html
xrrich
thanks guys i put 10 more litres in and took it for a spin and now runs a beaut. must of been lacking fuel
xrrich
Still being gay and cutting out, sounds like the fuel pump isnt working~?
xrrich
Ive checked all the hoses i took off and everything is back on, is it possible i might have trapped some lines inbetween the tank and the floor restricting flow? or could the fuel filter be the probelm.
It cut out 6 times this morning in less then a mile distance.
When i come to start it it takes a few mins to settle, its like i have to keep pumping fuel in, when you turn the ignition on?
GR40
could it be air in the tubes? did you bleeded the system?
xrrich
nope didnt bleed the system. its weird tho , car got me to edition 38 fine. its only when its low on revs
Could it be the power output from the car? I know the pumps prime when you turn the key but when the engine is running, they might run off the power produced from the alternator. If the alternator is old it could be that. If its not spinning fast enough at low revs the power output will beless, when you accelerate it spins faster producing a higher output. I have herd of people saying that when you have your headlights on then accelerate a little you can see them get brighter, usually due to alternator.
Just a thought?
If you wanna try another pump to see if your pumps arent gone i have both pumps that i removed a few months ago. Could send them to you to try them out?
xrrich
Could be, really annoying me now lol,
That would be brilliant if you were up for sending me the ppumps to try out,
Cheers RIch
GR40
It sounds something like my other car did! A renault 19. It would start some times and work just fine and next time it would give me hell and worked like shit! It was the pump at its final moments! But some other weird though just hit me! Well we all know that when you consume fuel air must go in the tank to replace the vacuum! Some tanks have a little hole on the cap witch when clogged gives you similar effects to what you describe, don't know how it's working with the g40 tank but just try running the car without the cap and see how it goes! ( have an extinguisher at hand as well  ;D)
xrrich
fuel pump isnt even priming when i turn the ignition. It wont start.
Help please
GR40
it only primes once! if its already primed it won't do it twice! check the connections to the pump or else it's just dead!
