how hard is to change a charger belt
Started by wbaxter90, July 22, 2010, 06:58:40 PM
wbaxter90
changing a charger belt?
ive been ill this week so my car still has a snapped belt, me and a mate were guna have a crack at it, were guna use a cam belt until i scope out a decent belt, but how hard is it to put one on? dont you slide the charger across and adjust the tensioning? also how can i test my pulley alignment? as it was a suggested cause of the belt snapping. cheers
edited by peteg40 - please use better subject headings
top bolt - 10mm allen key
side tensioning bolt - 19mm head normal bolt
loosen both. take belt off- replace belt.  Tension by putting a breaker bar in 1/2" hole in charger mounting bracket, while doing up both bolts.
Why use a cam belt with wrong tooth profile????  a HTD 1000 8m 20mm wide machine belt (presuming thats what your kit uses) will be as strong and available through bearing/seal/machine shop places locally to you.
wbaxter90
oh right kl didnt know that cheers il try and source one, thanks for the advice
vwmk3jon
Just order a belt from Pete. At least you'd know it was the right belt.
