Help - Please:-) - WHAT THE FOOK! interesting results inside
Started by youngprodigys, February 02, 2010, 10:21:28 PM
youngprodigys
Hi guys, im approaching the end of a very tiring rebuild 3+years.
And the time has come to setup my engine, needs the idle setting and the co2 potentiometer etc etc.
I wont lie - i havent a clue and im not going to drive it anywhere until its stopped idling fast. i know the timing is out, its a brand new dizzy and i dont have a timing gun.
Im hoping someone wants to come round and set it up for me to which i will pay for the privilege.
and to anyone who thinks there in for a game - take a look at the bay, you wont even get oil on your hands.
no fooking about it running
BRAND NEW SPARK PLUGS (G40 W5DPO OR SOMETHING)
BRAND NEW CAM BELT
BRAND NEW DIZZY (G40 BOSCH)
A PERFECT co2 POT
BRAND NEW PSD TOOTHIE PULLEYS
BRAND NEW BLUE TEMP SENSOR (VAG)
BRAND NEW VERNIER (UNADJUSTED)
no money has been spared on this,
Im located in Bedworth, which i 1 mile from J6 of the M6
Have you set the cam timing correctly?
What chip are you using?
What injectors?
Have you set the CO pot to ~550ohms?
If you get really stuck I might be able to help (am about 25 miles away), but I'm short on time at the moment!
youngprodigys
The cam timing (pulley) is unadjusted, its 100% as VW intended, the camshaft is a PSD 1341 eaton spec.  the chip is from Gwerks and is mapped to suit the spec. running G60 injectors, and the co2 pot i have set at 550ohms (pins 1-3 done with multimeter)
i have done some research, but id rather have a G40 guru turn up!
sinister polo
sorry to go off topic but is that a tt dash i see fitted and some rallye headlights?
Varley
Can't help you out with your setup mate but that 'bay looks the b*llocks! - fair play.
If you can get it to Jct 18 of the M6 I don't mind setting it up  ;)
is the idle screw all the way in?
is the throttle body dewedged and not leaking?
obviously an air leak letting too much air in at some point.
vwmk3jon
Mine idles quite high when its cold although im running 300cc injectors.
giorgio
I can get you a timing gun if you want?
youngprodigys
No MOT on the thing as you can imagine after being 3yrs in the making - so no trip to junction 18 :-(
i have tried screwing th idle all the way in and it goes until it bottoms out. still fast idle.
the throttle body is on brand new gaskets and is dewedged. it must have an air leak somewhere i just cant find it.
and to be honest it is so much easier if i had someone who knew what to look for and how to set it. lovely of the offer giorgio,but getting a timing gun isnt an issue - its using the fooker - properly
there must be someone close who can help.....££££££ money to be earnt;-)
giorgio
I am upto my nuts in Portuguese trying to get a car + a shit load of flight cases to Brazil so cant lend a hand but will ask about tomorrow if somebody fancies is.
jez1272gt
Seriously smooooth!! i like that alot .... good luck with the set-up matey!
youngprodigys
cheers,
the offer is wicked giorgio but i just cannot let just anyone loose on my engine. they HAVE to know the G40. there is to much money and time gone into this to have someone who isnt up to speed come and detonate the fooker. they have to be clued up.
thats why im asking on here as the peps seam a lot more into the G40 then the "will a electric supercharger make my car go faster" club polo crew,
youngprodigys
idle has been sorted. so now its a case of setting up the sensors to make it run as it should. saying that its running pretty sweet:-)
ANSWER TO THE FAST IDLE IS VISABLE IN THE PICTURE - Blue peter badge to the winner
Alexiskayak_7
the fuel pressure regulator vaccum pipe?
