Author Topic: Help - Please:-) - WHAT THE FOOK! interesting results inside  (Read 17980 times)
Offline G40supercharged
Re: Help - Please:-) - WHAT THE FOOK! interesting results inside
« Reply #90 on: April 01, 2010, 05:54:26 pm »
Details of which transistor to change for ignition coil not firing are towards the end of the thread below (it may not be the problem but its cheap enough to give it a try).
http://www.clubpolo.co.uk/forum/index.php?showtopic=110223&hl=
Offline youngprodigys
  • G 3URO
« Reply #91 on: April 01, 2010, 06:05:37 pm »
that maybe a very good way to make myself some coin! if I can fix it il use it and flog the other. nice one mate!
Offline vwmk3jon
« Reply #92 on: April 02, 2010, 04:30:35 pm »
Depends on what the G-werks map you have is for spec wise. Mine passed a MOT easily with the chip in. Had to rev it abit to keep it running tho.
  • G 3URO
« Reply #93 on: April 02, 2010, 07:07:15 pm »
perks of working in an electronics lab assembling antiskid circuit boards for aircraft- I can use the equipment:-) and 1 22p transistor later and the broken ecu is fixed! awesome lad. gunna install a bigger map sensor now.
my car is a 1994 so I should have a cat- but don't so I need the emissions really low
Offline hardchargin40
  • Older, Wiser, Greyer.
    • The Roadster.net
« Reply #94 on: April 02, 2010, 10:58:42 pm »
So your to blame for our recent spate of NWS and AS faults, lol. ::) :D
  • G 3URO
« Reply #95 on: April 03, 2010, 06:46:27 pm »
hahahaha lol - depends on which aircraft it is you have these faults on!
