G40 part numbers
Started by bbspolo, November 16, 2009, 11:17:38 AM
bbspolo
I know these sort of questions have been asked 2 death!
So how about a sticky with all the part number listed?
Pls only post ones of things you have bought and fitted so you know there correct!
Ive been seaching the forum looking for them so ill start us off with what i found!
Crank Bearings [Set of 5] 026 198 491 A
Gudgeon Pin 052 105 431
Con Rod Bolt 052 105 425 A
Hex Nut [Rod Bolt] 052 105 427
Bearing [Rod to Crank] 031 105 701 A
Thrust Washers 026 198 421
Also get - 052 105 313. Its a bush that goes on the end of the crank between the flywheel.
lance
#1
also,
oil pump 030115105E £105.96
water pump 030121005LX £34.00
timing belt (late) 030109119A £11.05
bbspolo
Fantastic keep them coming all the parts i find im ordering in for our stock and when complete will give you all a complete price list!
Fred
#3
Bought these a few Month`s ago at VW
Prices include Vat at 15%
Oil Pump Drive Chain                                     030 115 125 A  £21.99p
Piston Rings                                                030 198 151     £103.99p
Front Brake Disc (splashguard) Coverplate        867 615 311 B &
        867 615 312 B  £14.90p each side
Alloy Oil Pump Cover Paper Gasket                  030 103 161 C  £3
Strut Top Bearing Mounts (Retainers)              871 412 323 A  £18.59p Each
Front Wheel Bearing                                    871 498 625 A   £19.99p Each
Front Strut Plastic Boot                               861 412 135      £1.56p  Each
Fred.
when people have bought things, could they give an indication of price please
supercharged spaniel
#5
Heres a few.  Prices are all approx and off the top of my head but should give some idea of cost.
loom tape 000979950 - £3.50
exhaust rear box 871253609G - £180
corrogated boost pipe 871145828C- £89
long plastic boost pipe 871145895 - £15
Radiator 867121253AB - £96
Expansion tank 1H0121407A - tbc
thermostat housing 0301211117M - £24
thermostat 0301211113 - £7
lambda probe 030906265J - £60-80
oil filter 030115561AB £3.50
knock sensor 030905377 £50
Daryl
fred how long ago did you get piston rings as i tryed at my local  branch back in aprill to say they cant get them anymore.
I will dig out some paper work as ive got some bottom end parts
Fred
#7
Bought Piston Rings 20/03/09 fella.
I priced up big end shells and main bearings at the time
and think it was around £220 for the lot.
Fred.
bbspolo
Ive got piston rings on order from german at the moment for mr jackson!
if you want a set give me a call at redhill branch and ill sort a set out for you!
Dan
Daryl
Could do with a set what sort of price are they from your branch also would i have to collect.
bbspolo
no mate i should be able 2 sort it so u can pick them up at any branch! (may just take a little longer, but if there just for spares then that shouldnt be a problem!) give us a call!
Dan ecp redhill
vwmk3jon
anyone got the part number for the ISV please?
Alexiskayak_7
049 133 453 E (G40 specific)
vwmk3jon
grayg40
cylinder head to exhuast manni gasket 030 253 039 A. you need 2 of these they sell them as 2
price is £10.64 for both
manni to downpipes gasket 871 253115 A. price £10.88.
the prices are exculding vat
