Club G40 => General Car Chat => Topic started by: bbspolo on November 16, 2009, 11:17:38 am
I know these sort of questions have been asked 2 death!
So how about a sticky with all the part number listed?
Pls only post ones of things you have bought and fitted so you know there correct!
Ive been seaching the forum looking for them so ill start us off with what i found!
Crank Bearings [Set of 5] 026 198 491 A
Gudgeon Pin 052 105 431
Con Rod Bolt 052 105 425 A
Hex Nut [Rod Bolt] 052 105 427
Bearing [Rod to Crank] 031 105 701 A
Thrust Washers 026 198 421
Also get - 052 105 313. Its a bush that goes on the end of the crank between the flywheel.
also,
oil pump 030115105E £105.96
water pump 030121005LX £34.00
timing belt (late) 030109119A £11.05
Fantastic keep them coming all the parts i find im ordering in for our stock and when complete will give you all a complete price list!
Bought these a few Month`s ago at VW
Prices include Vat at 15%
Oil Pump Drive Chain 030 115 125 A £21.99p
Piston Rings 030 198 151 £103.99p
Front Brake Disc (splashguard) Coverplate 867 615 311 B &
867 615 312 B £14.90p each side
Alloy Oil Pump Cover Paper Gasket 030 103 161 C £3
Strut Top Bearing Mounts (Retainers) 871 412 323 A £18.59p Each
Front Wheel Bearing 871 498 625 A £19.99p Each
Front Strut Plastic Boot 861 412 135 £1.56p Each
Fred.
when people have bought things, could they give an indication of price please
Heres a few. Prices are all approx and off the top of my head but should give some idea of cost.
loom tape 000979950 - £3.50
exhaust rear box 871253609G - £180
corrogated boost pipe 871145828C- £89
long plastic boost pipe 871145895 - £15
Radiator 867121253AB - £96
Expansion tank 1H0121407A - tbc
thermostat housing 0301211117M - £24
thermostat 0301211113 - £7
lambda probe 030906265J - £60-80
oil filter 030115561AB £3.50
knock sensor 030905377 £50
fred how long ago did you get piston rings as i tryed at my local branch back in aprill to say they cant get them anymore.
I will dig out some paper work as ive got some bottom end parts
Bought Piston Rings 20/03/09 fella.
I priced up big end shells and main bearings at the time
and think it was around £220 for the lot.
Fred.
Ive got piston rings on order from german at the moment for mr jackson!
if you want a set give me a call at redhill branch and ill sort a set out for you!
Dan
Could do with a set what sort of price are they from your branch also would i have to collect.
no mate i should be able 2 sort it so u can pick them up at any branch! (may just take a little longer, but if there just for spares then that shouldnt be a problem!) give us a call!
Dan ecp redhill
anyone got the part number for the ISV please?
049 133 453 E (G40 specific)
Cheers chap :)
cylinder head to exhuast manni gasket 030 253 039 A. you need 2 of these they sell them as 2
price is £10.64 for both
manni to downpipes gasket 871 253115 A. price £10.88.
the prices are exculding vat
anyone got the oil breather part number? i cant seem to find it on etka, well i can find it but not the part number!
it's the same part as a mk2 one dan
G40 breather pod dome - 030 103 129
One of the many bits ordered for my rebuild, so got all the numbers to hand.
VW bottom arm inside bush for G40
823 407 181
£7.93 + vat
Lift Pump - 357 906 092 C
Main Pump - 867 906 091
Rocker Cover Bolt - 030 103 531
Just thought i would sort out the part numbers and make them look a bit better. I have these saved so when they come in i will update the list. Not all prices are update or are not given.
bush between crank and flywheel 052 105 313
oil pump 030 115 105E £105.96
water pump 030 121 005LX £34.00
O-ring water pump 030 121 043B £3.00
timing belt (late) 030 109 119A £14.73 incl VAT
Oil Pump Drive Chain 030 115 125A £21.99p
Front Brake Disc (splashguard) Coverplate 867 615 311B &
Alloy Oil Pump Cover Paper Gasket 030 103 161C £3.00
Strut Top Bearing Mounts (Retainers) 871 412 323A £18.59p Each
Front Wheel Bearing 871 498 625A £19.99p Each
loom tape 000 979 950 £3.50
exhaust rear box 871 253 609G £180.00
corrogated boost pipe 871 145 828C £89.00
long plastic boost pipe 871 145 895 £15.00
Radiator 867 121 253AB £96.00
Expansion tank 1H0 121 407A
thermostat housing 030 121 1117M £24.00
thermostat 030 121 1113 £7.00
lambda probe 030 906 265J £122.97
oil filter 030 115 561AB £3.50
knock sensor 030 905 377 £50.00
ISV? (G40 specific) 049 133 453E
exhuast mannifold gasket 030 253 039A £13.58 incl VAT
mannifold to downpipe gasket 871 253 115A £10.88
Washers for manifold studs N 011 558 11 £0.18p each
Manifold studs N 044 410 4 £0.66p each
Manifold stud Nuts N 900 850 01 £0.33p each
G40 breather pod dome 030 103 129
bottom arm inside bush for G40 823 407 181 £7.93
Water pump O-ring 030 121 043B £3.00
Outer window seal 867 837 477 £20.61
Outer window seal 867 837 478 £20.61
Inner window seal 867 837 479 £14.00
Inner window seal 867 837 480 £14.00
Lift Pump 357 906 092 C £38.90
Main Pump 867 906 091 £167.00
Rocker Cover Bolt 030 103 531 £12.42
Any one got part number for Driveshaft bolts, cam shaft bolt and crank shaft bolt?
i do will let know when i come back from the unit later.
Drive shaft : 893 407 237
Cam shaft : N 902 562 01
Cam shaft washer : 027 109 143
Crank shaft : N 902 928 02
Anyone got the part number for the crank seal? Mine is leaking.
068 103 085 E - small, oil pump cover plate.
068 103 051 - large, flywheel side, but obsolete from VW. Only available from them as: -
068 103 171 F - cover plate, flywheel side from VW WITH above obsolete seal ??? Pricey though, over £60.
Bottom cam belt pulley bolt , Short tough tight one . Has anyone got the part number for it as I can't find it on VAGCAT.
Etches
Found it ;
N90292802
M14x 1.5
Can any one confirm what the G40 engine mount and gear box mount part no is?
Is the gearbox mount / rubber slightly different?
