G40 part numbers
Started by bbspolo, November 16, 2009, 11:17:38 AM
DKnight
anyone got the oil breather part number? i cant seem to find it on etka, well i can find it but not the part number!
it's the same part as a mk2 one dan
Puncharado
G40 breather pod dome - 030 103 129
One of the many bits ordered for my rebuild, so got all the numbers to hand.
grayg40
VW bottom arm inside bush for G40
823 407 181
£7.93 + vat
pettsy
Lift Pump - 357 906 092 C
Main Pump - 867 906 091
Rocker Cover Bolt - 030 103 531
Just thought i would sort out the part numbers and make them look a bit better. I have these saved so when they come in i will update the list. Not all prices are update or are not given.
Crank Bearings [Set of 5]                026 198 491 A
Gudgeon Pin                      052 105 431
Con Rod Bolt                      052 105 425 A
Hex Nut [Rod Bolt]                   052 105 427
Bearing [Rod to Crank]                   031 105 701 A
Thrust Washers                      026 198 421
bush between crank and flywheel                            052 105 313
oil pump                              030 115 105E    £105.96
water pump                             030 121 005LX    £34.00
O-ring water pump                   030 121 043B      £3.00
timing belt (late)                           030 109 119A    £14.73 incl VAT
Oil Pump Drive Chain                                        030 115 125A     £21.99p
Piston Rings                                                           030 198 151       £103.99p
Front Brake Disc (splashguard) Coverplate              867 615 311B &
        867 615 312 B     £14.90p each
Alloy Oil Pump Cover Paper Gasket                        030 103 161C     £3.00
Strut Top Bearing Mounts (Retainers)                    871 412 323A     £18.59p Each
Front Wheel Bearing                                          871 498 625A      £19.99p Each
Front Strut Plastic Boot                                     861 412 135        £1.56p  Each
loom tape                              000 979 950     £3.50
exhaust rear box                           871 253 609G     £180.00
corrogated boost pipe                   871 145 828C    £89.00
long plastic boost pipe                        871 145 895    £15.00
Radiator                              867 121 253AB    £96.00
Expansion tank                      1H0 121 407A
thermostat housing                                               030 121 1117M    £24.00
thermostat                              030 121 1113    £7.00
lambda probe                      030 906 265J    £122.97
oil filter                              030 115 561AB    £3.50
knock sensor                      030 905 377    £50.00
ISV? (G40 specific)                  049 133 453E
exhuast mannifold gasket                030 253 039A     £13.58 incl VAT
mannifold to downpipe gasket                       871 253 115A    £10.88
Washers for manifold studs                N 011 558 11   £0.18p each
Manifold studs                     N 044 410 4   £0.66p each
Manifold stud Nuts                   N 900 850 01   £0.33p each
G40 breather pod dome                030 103 129
bottom arm inside bush for G40             823 407 181    £7.93
Water pump O-ring                       030 121 043B      £3.00
Outer window seal                        867 837 477      £20.61
Outer window seal                        867 837 478      £20.61
Inner window seal                        867 837 479      £14.00
Inner window seal                        867 837 480      £14.00
Lift Pump                              357 906 092 C   £38.90
Main Pump                              867 906 091   £167.00
Rocker Cover Bolt                   030 103 531   £12.42
Any one got part number for Driveshaft bolts, cam shaft bolt and crank shaft bolt?
Daryl
i do will let know when i come back from the unit later.
Daryl
Drive shaft : 893 407 237
Cam shaft : N 902 562 01
Cam shaft washer : 027 109 143
Crank shaft : N 902 928 02
Anyone got the part number for the crank seal? Mine is leaking.
Puncharado
Quote from: Jezza-7 on September 07, 2010, 07:00:19 PM
068 103 085 E - small, oil pump cover plate.
068 103 051 - large, flywheel side, but obsolete from VW. Only available from them as: -
068 103 171 F - cover plate, flywheel side from VW WITH above obsolete seal  ??? Pricey though, over £60.
Etches
Bottom cam belt pulley bolt , Short tough tight one . Has anyone got the part number for it as I can't find it on VAGCAT.
Etches
Etches
Found it ;
N90292802
M14x 1.5
JoeH
Can any one confirm what the G40 engine mount and gear box mount part no is?
Is the gearbox mount / rubber slightly different?
