Author Topic: Aquamist questions  (Read 7489 times)
Offline vwmk3jon
Aquamist questions
« on: November 04, 2009, 07:04:47 pm »
Need to buy some vacuum hosing and high pressure poly tubing for my kit.
Where'd be the best place to buy it from?
How do you measure the nozzle size and what would be the best size to use?
The nozzle goes into the boost pipes after the intercooler. Am i best of drilling a hole into my boost pipe (its metal) and screwing the nozzle in?
Re: Aquamist questions
« Reply #1 on: November 04, 2009, 07:18:04 pm »
ERL (aquamist) sell nylon tubing which is what I use with mine, since it's an ERL kit anyway.
You can also get the nozzles from ERL, 0.3mm is what people tend to use on g40s.
Yeah screwing it into a hole drilled into a solid pipe is the best bet.  If you use an ERL nozzle you need to get an m8x0.75mm thread tap which can be bought from ERL again or off ebay.
Offline vwmk3jon
« Reply #2 on: November 04, 2009, 07:52:59 pm »
Mines a coolingmist kit so not really a proper aquamist kit (but does the same thing).
You think the nozzles will be the same? I got 3 nozzles with mine but have no idea what size each one is!
Offline vwmk3jon
« Reply #3 on: November 05, 2009, 02:53:40 pm »
Offline dub-disaster
« Reply #4 on: November 05, 2009, 03:06:55 pm »
is the cooling mist kit just as good as the aqumist kit as its a damn sight cheaper and includes a tank !! or is the aquamist alot better kit ??
Offline vwmk3jon
« Reply #5 on: November 05, 2009, 07:19:11 pm »
I cant give you an answer on that as i got my kit pretty cheap off ebay! I didnt get a tank though so need to find one (preferably a shiny one).
« Reply #6 on: November 05, 2009, 09:32:02 pm »
i got a shiny tank for sale in the classifieds at the moment!! have a look, let me know how it works out cause this kit is cheeeaaap!!
Offline vwmk3jon
« Reply #7 on: November 05, 2009, 09:52:00 pm »
Mine was well cheap - £120  ;D
i'll have a looksie at the tank and let you know.
Offline vwmk3jon
« Reply #8 on: November 06, 2009, 12:01:44 am »
will silicone pipe be affected by methanol?
Offline vwmk3jon
« Reply #9 on: November 06, 2009, 10:41:07 pm »
...and am i right in thinking the boost valve cotrol thing would be best off being inserted into the pipe from the ECU?
« Reply #10 on: November 07, 2009, 11:50:22 am »
no dont put anythign in the pipe to the map sensor
Offline supercharged spaniel
  • GRRRRRRR
« Reply #11 on: November 07, 2009, 02:33:48 pm »
someone explain aquamist on a g40 pleeeease  :)
Offline lance
« Reply #12 on: November 07, 2009, 05:51:44 pm »
it squirts a fine mist of water into your boost to lower charge temps to save your engine from heat mainly for saving your valves, once mixed with methonal it gives you peformance advantages.
  • GRRRRRRR
« Reply #13 on: November 07, 2009, 05:53:57 pm »
interesting...thanks :D
« Reply #14 on: November 08, 2009, 03:51:20 pm »
it's a good way of suppressing detonation, the methanol burns slowly and in a controlled manner meaning that you can have more ignition advance with high boost and hence more power.  And it also reduces inlet temps too.
