Aquamist questions
Started by vwmk3jon, November 04, 2009, 07:04:47 PM
vwmk3jon
Quote from: hayesey on November 07, 2009, 11:50:22 AM
no dont put anythign in the pipe to the map sensor
Ah, ok. I'm slowly working out how to install it (instructions are confusing!), just lot on afew things......
Where does the boost control valve plumb in?
flow of pump (which is inlet & outlet)
flow of filter (isnt the same as shown in instructions!!)
vwmk3jon
Make it abit easier......
Inline filter. I know it goes between the tank and the pump but which way round?
pressure switch? I'm unsure if i need this and if i do, how it wires in as all the wiring i have i've accounted for
all the wiring labelled :)
did the kit not come with any instructions?  Not sure how much help I can give really, I know how my ERL Aquamist kit goes together but this one is different.  The ERL kit comes with a proper loom with connectors and full instructions.
You'll need the pressure switch though, that's what actually actives the aquamist, otherwise it'd either be on constantly or never on at all.
vwmk3jon
I've downloaded the instructions but they're not very clear at all!
I'll have a play around with the bits and see what happens.
do you have a link for the instructions?
Quote from: vwmk3jon on November 09, 2009, 01:24:23 PM
LOL - sounds like a kid playing with matches...
vwmk3jon
i'm not that bad! (am i?)
unless im blind (quite possible), i cant find no mention of the pressure switch so unsure where it goes and not sure of the flow of the pump and filter as the filters different to the one shown in the instructions and neither had any markings on to show this.
Instructions are in PDF format. I'll find a linky......
pressure switch should act like and on/off switch for the pump so it only switches on at decent boost levels.
vwmk3jon
Quote from: PeteG40 on November 09, 2009, 02:44:04 PM
So i'd assume it goes before the pump?
Been looking at install pics online to try and work out where stuff goes.
wiring to boost switch, pump and connected relay is sorted. Its just the damn pressure switch (although i do have an idea......)
vwmk3jon
page five tells you what to do with the boost switch, although the one in your pic doesn't look like the one in the instructions.
vwmk3jon
Thats what i thought!
Well the worst that can happen is i wire it in and it doesnt work in which case im sure it'll be the case of swapping afew wires round.
May have a look tomorrow, depending on when i get home/weather/how tired i am!
Dirty Slag
Worst case it can fill your engine with water and totally screw it up!
Why even bother with this stuff aqau mist/methanol is normally used on mega high boost applications unless your running over 200bhp you may as well just get a bigger fmic so much easier to fit and no water or wiring to screw up and prob cheaper!
vwmk3jon
I'll obviously test the kit before final fitment.
My FMIC is quite big already (AWT item)
