Quote from: Justin14100 on October 28, 2009, 11:22:34 amWhy is RAE's car less power than the standard one of pete's?is it cause its running a standard chip? so the fueling isn't correct?Always thought that the 65mm pully made a decent difference?because it's running poo... i've a disitegrating rotor arm too... i've a compression test to do... and to hook up the boost gauge againthe 65mm pulley caused mine to go lean at top end as it was standard chip... also, i'm on an "8P" box until i fit the "ATV" - if that alters the readings at all?mine just needs some love - i've not had it long and had no time to tinker!!!!
Quote from: Justin14100 on October 28, 2009, 11:52:28 amp.s you actualy giner; seen your avatar's - if so that makes 2 of us on here!no its not ginger lol...
