well i have tried the car without the belts on and the sound has gone
so i was about to take the charger off when i decided to take the oil feed pipe off and check there was oil going through it, i had the pipe hanging out on the side of the car with the car running but no oil at all. so i decided to take the tee piece out and run the car with the hole open and oil does come out of the hole but not when the oil feed pipe is on, tee piece is clear, and i have even connected the oil feed pipe straight onto the hole at back of head but still no oil. but if i take the pipe off and blow through it is clear. i have even tried sucking it through just incase there is an air lock but i cant suck a golfball through a hose pipe as this is what it feels like. still no oil
is there anything im doing wrong and im sure this could be the cause of my grindy noises as it will be getting no oil into the charger
