Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Technical
Chassis & Braking
bleeding brakes
« previous
next »
Pages: [
1
Go Down
Author
Topic: bleeding brakes (Read 2817 times)
ahmed bayjoo
bleeding brakes
on:
April 07, 2009, 04:16:14 pm »
can anybody tell me the correct method to bleeding the brakes,
not sure how it is done if you dont have rear calipers.
thanks
Administrators
Housewives heart throb
Re: bleeding brakes
Reply #1 on:
April 07, 2009, 04:38:40 pm »
bleed the rear drums from the cylinder nipple at the back fo the drums - starting with furthest run from the master cylinder.
Dan
Re: bleeding brakes
Reply #2 on:
April 07, 2009, 06:15:55 pm »
A tip is to hold open the rear pressure regulator so as to not restrict the fluid to the rear drums. A tiny cable on the pressure reg does the trick !
Administrators
Re: bleeding brakes
Reply #3 on:
April 07, 2009, 06:59:06 pm »
true dan.. or i pull it open and lightly clamp it with mole grips
Pages: [
1
Go Up
« previous
next »
Technical
Chassis & Braking
bleeding brakes
