bleeding brakes
Started by ahmed bayjoo, April 07, 2009, 04:16:14 PM
ahmed bayjoo
can anybody tell me the correct method to bleeding the brakes,
not sure how it is done if you dont have rear calipers.
thanks
bleed the rear drums from the cylinder nipple at the back fo the drums - starting with furthest run from the master cylinder.
Dan
A tip is to hold open the rear pressure regulator so as to not restrict the fluid to the rear drums. A tiny cable on the pressure reg does the trick !
true dan.. or i pull it open and lightly clamp it with mole grips
