Author Topic: Quaife ATB diff - will it kill my driveshafts  (Read 11230 times)
Offline Alex
  • Hack
« on: January 28, 2009, 07:21:45 pm »
I've sorted myself out with a Quaife ATB diff today, which I'm very happy about! :)
One thing worries me though, I'm still running GT driveshafts.
Have I just bought myself a one way ticket to a snapped driveshaft?
Offline giorgio
Re: Quaife ATB diff - will it kill my driveshafts
« Reply #1 on: January 28, 2009, 07:30:27 pm »
I have to check ETKA but I think GT shaft are same as normal polos.
More importantly the inner CVs are the same. My G chewed through one of these in about 20 seconds [no exaggeration]
That may be more the nature of my clutch so you may be ok.
Go G40 since the box is coming off
« Reply #2 on: January 28, 2009, 07:40:15 pm »
have been running LSDs and driveshafts from a non-g40 for years and never snapped one.  Where they tend to fail is the same on a g40 shaft and non-g40 shaft anyway which is just before the spline part on the outer end.
Offline Alex
  • Hack
« Reply #3 on: January 28, 2009, 07:42:18 pm »
I think I'll try it, fuck it, if I break a driveshaft I'll be as out of pocket as I would be from changing it on spec.
Is anyone making them any more though?
Oh yeah, and what's a standard clutch good for power wise?
Offline lance
« Reply #4 on: January 28, 2009, 07:47:27 pm »
i have had mine uprated pick it up next  onth ill take photos for you all,
standard clutch should take about 160 bhp.
« Reply #5 on: January 28, 2009, 07:59:55 pm »
a clutch would be rated more by torque than bhp.  I remember Paul Borthwick used to get on just fine with 170bhp on a standard clutch.  Just an uprated one will last longer.
Offline Alex
  • Hack
« Reply #6 on: January 28, 2009, 08:09:06 pm »
Something else to look into then!
Offline Alex
  • Hack
« Reply #7 on: January 28, 2009, 08:10:16 pm »
Sorry, I didn't explain that, I reckon after a cam, headwork and a rolling road remap (all coming up) it'll be around 160bhp. Probably a bit under.
« Reply #8 on: January 28, 2009, 08:12:11 pm »
yeah I'd probably be happier using something along the lines of a helix organic clutch at that point.
Offline Alex
  • Hack
« Reply #9 on: January 28, 2009, 09:33:56 pm »
I had a feeling you were going to say that! Not a massive problem, worth it in the long run too.
Offline Dan
« Reply #10 on: January 28, 2009, 09:47:14 pm »
Alex, are these Diffs readily available or availble to order from Quaife ?
Offline Alex
  • Hack
« Reply #11 on: January 28, 2009, 10:33:50 pm »
They're in stock, yes.
Offline polo classic
« Reply #12 on: January 29, 2009, 02:41:48 pm »
You must be lucky (or drive like a granny) then, I thought the record with a plate diff was 2 weeks for the stock shafts :P
« Reply #13 on: January 29, 2009, 02:46:45 pm »
I don't drive it like a granny at all, I guess I've just been lucky.  I've ruined a couple of ATVs and snapped a gemini diff in half but driveshafts have been fine.
« Reply #14 on: January 29, 2009, 02:49:06 pm »
did all the cup cars have uprated driveshafts then?  I thought they were all standard
