Author Topic: Possible blocked injector  (Read 2362 times)
Offline matthg40
« on: June 09, 2018, 04:04:55 am »
What is the best and safest way to check if I have a blocked injector very random question but there is always method in my madness 😬 also I red something about removing the resistor from my rotary arm as I think my g is still detonating after setting the timing after the rebuild so still in the process of setting her up.
« Last Edit: June 09, 2018, 04:25:30 am by matthg40 »
Offline GR40
Re: Possible blocked injector
« Reply #1 on: June 11, 2018, 02:14:57 pm »
Color of spark plug is usually the easiest way to know if one cylinder is leaning out. There are plenty of pictures to compare on the interwebs.
Offline matthg40
« Reply #2 on: June 12, 2018, 10:30:49 am »
Nice one dude I had I look in my Haynes yesterday just wondered if there was a more in depth suggestion I’ll check this morning
Offline ereeiz
« Reply #3 on: June 12, 2018, 11:45:56 am »
Swap it with another one and see if the issue moves. You got a laser thermometer? You can point that at your exhaust headers and see if there's a difference in temperature (cold one compared to the others = not working properly)
