Belt left on the mway at 80
Started by batten, January 11, 2009, 01:01:57 PM
batten
well i no longer have a toothed drive belt as it left me on the motorway friday night at 11pm  >:( got recovered eventually after nearly freezing to death.
The car had been sounding rough on idle for a few days and stupidly i wanted to wait till the weekend to investigate,should have retired the car but just needed to get places. It went silent after 1.5k and i dismissed the belt being the issue.
Looking at the pulleys now they looked like they have been abbraised as they are quite shinney in places, so i dont know whether a stone or something had got caught it the belt? sounds silly.
So im going to be ordering a new one, would this be corerect?
http://www.jabbasport.com/store/index.php?app=gbu0&ns=prodshow&ref=G-LADER04
How much play should be left in the belt once fitted?
sorry for the Q's but im new to all this
thanks for any help,
John
Nick_S
If i'm not mistaken, thats the charger timing belt on Jabba site. If that went on yours, the charger would have grenaded!
I guess you mean toothed pulley belt?
batten
Ah sorry Nick yes thats the one! cant seem to find them online. but its defo the external belt linking the alternator
batten
how worn are your toothed pullies?  Have you been using the proper belt on them or just a timing belt?    That one we sell is a proper one.
batten
they arnt that bad just a little shinny in places tbh just had another look. im guessing that it was the correct belt in the 1st place
Dan
If you have a stone fly up and hit it, then it could have caused it to break.
G-spot
Quote from: batten on January 11, 2009, 01:01:57 PMHow much play should be left in the belt once fitted?
I'm on my original belt of +20K miles, an I run it with plenty of play/give, no were near as tight as either my cambelt or the OEM V-belts, keeping these belts slack will also vastly reduces bearing wear too, I can get a 180 degree twist without too much trouble between the charger and crank pulley with my belt. I have got some evidence of bits of forign body(grit/stones) getting caught between the pulley and belt, but nothing that has caused a failure.
batten
right ok cheers for that info, so best to leave a slight bit of play then
I used to tighten mine up the same tightness as a cambelt, so you could only twist it 90deg between the bottom pulley and the charger pulley, lasted years like that.  In fact I never had a belt snap, I replaced it once just because the old one was old.
Jake
Very strangely.....I read this thread about 4pm today. Then I popped out to do some work and on the way home my belt snapped! Gutted. So gotta order 2 asap as its my daily driver!
batten
wow that spookey, i dont feel so alone now! i hate it when the daily is out of action
I'd advise anyone with toothed belts to carry a spare in the boot.  I did even though I never needed it.  It's not like you can get the correct ones in any halfords like you can with a fan belt.
Jake
Yeah I'm buying 2 this time so I got a spare. Messaged pete so just awaiting a reply now...
