Author Topic: Subframe measurements  (Read 4136 times)
Offline physicsfool
« on: August 10, 2015, 02:32:11 pm »
I am looking for the PPP subframe distance between the 2 sets of ARB block holes.
1. Distance between the holes
2. Distance between the 2 sets of holes
3. Diameter of hole for arb blocks bolts
I am modifying a PPS subframe to make it a bit more stable.
Ta
Re: Subframe measurements
« Reply #1 on: August 10, 2015, 03:55:03 pm »
aren't these dimensions kind of dictated by the positions of the corresponding holes on the car?  There's not really any adjustment there.
Offline physicsfool
« Reply #2 on: August 10, 2015, 04:17:56 pm »
Yes, but mine may be distorted due to twisting. The main one is the distance between the two legs as i will probably get a new plate welded to the subframe as the current one has grooves and not holes
« Reply #3 on: August 10, 2015, 09:16:07 pm »
Best bet is to buy a PPP frame...  ;)
Second best bet, fit it to the car, tack the repair sections in (thick washers will work) then remove and weld up.
Offline physicsfool
« Reply #4 on: August 10, 2015, 11:35:19 pm »
Do you do a trade in service or maybe student discount. Times are hard for us tax dodging folk
« Reply #5 on: August 11, 2015, 07:00:49 am »
I'm afraid not  :D
Offline physicsfool
« Reply #6 on: August 11, 2015, 08:08:15 am »
Cheers anyway, will try the putting it in place and tacking a washer on
