Author Topic: 13" alloys over 256 brakes  (Read 9154 times)
Offline Jezza-7
« on: August 05, 2013, 07:45:32 pm »
What size spacers would you need with 13" alloys?
« Last Edit: September 17, 2013, 03:15:42 pm by hayesey »
Re: 13" alloys over 256 brakes
« Reply #1 on: August 05, 2013, 07:51:05 pm »
fucking big ones!
« Reply #2 on: August 05, 2013, 08:12:07 pm »
2"
Offline Phil
« Reply #3 on: August 05, 2013, 10:11:43 pm »
All depends on the wheel. Quite a few split rims happily fit over 256mm brakes without silly offsets.
« Reply #4 on: August 06, 2013, 09:52:56 am »
the vast majority of 13" wheels wont fit, not even close.
some will, usually ones aimed at motorsport.   Some compomotive wheels are pretty good for this.
« Reply #5 on: August 06, 2013, 10:02:29 am »
Which ones?
Offline Tav
« Reply #6 on: August 06, 2013, 11:12:39 am »
I think a compomoive CXR is known for having a lot of brake clearance, would like to get a hold of one to try.
I tried MB mini alloys once and I think they would have fit with a 20mm spacer or a better offset.  Split rim type job.
Offline Phil
« Reply #7 on: August 06, 2013, 11:34:36 am »
Off the top of my head, Tramont's fit over 256mm.
As do some Compo's
Offline Jezza-7
« Reply #8 on: August 06, 2013, 12:37:01 pm »
Just i wouldnt mind getting some 13's to run slicks as 14's are not great size.
May have a look into comp's then.
« Reply #9 on: August 06, 2013, 12:57:26 pm »
Jezza- Try mine this weekend if you want, I've got ET20 and ET0, the latter won't fit with your arches.
Phil- What offset on the tramont? Mathers always used t run spacers, even with 239mm single pot caliper  ???
Offline Jezza-7
« Reply #10 on: August 06, 2013, 05:30:48 pm »
Ok mate, that will be good.
Might not be running as i only have the paper part of my license but gonna cal them to see if thats enough.
Offline Robin
  • 194bhp - 1341 Turbo
« Reply #11 on: August 06, 2013, 10:25:45 pm »
Jezza when mine shits itself you can borrow my drag slicks to do a few runs!
Offline Jezza-7
« Reply #12 on: August 06, 2013, 10:43:23 pm »
Haha, cheers Robin. Would like to see what difference they make.
Offline PR23M3K
« Reply #13 on: August 06, 2013, 10:46:15 pm »
What about BRAID WINRACE A ? I read somewhere that they fit on 262 mm brake caliper (but in Honda) without spacers.
ps. weight of the alloys .... 4,1 kg / pc
Offline SamG40
  • Take.... on.... me....
« Reply #14 on: August 07, 2013, 08:51:21 am »
Such confidence!
