13" alloys over 256 brakes
Started by Jezza-7, August 05, 2013, 07:45:32 PM
What size spacers would you need with 13" alloys?
Phil
All depends on the wheel. Quite a few split rims happily fit over 256mm brakes without silly offsets.
the vast majority of 13" wheels wont fit, not even close.
some will, usually ones aimed at motorsport.   Some compomotive wheels are pretty good for this.
Quote from: Phil on August 05, 2013, 10:11:43 PM
Which ones?
Tav
I think a compomoive CXR is known for having a lot of brake clearance, would like to get a hold of one to try.
I tried MB mini alloys once and I think they would have fit with a 20mm spacer or a better offset.  Split rim type job.
Phil
Off the top of my head, Tramont's fit over 256mm.
As do some Compo's
Just i wouldnt mind getting some 13's to run slicks as 14's are not great size.
May have a look into comp's then.
Jezza- Try mine this weekend if you want, I've got ET20 and ET0, the latter won't fit with your arches.
Phil- What offset on the tramont? Mathers always used t run spacers, even with 239mm single pot caliper  ???
Ok mate, that will be good.
Might not be running as i only have the paper part of my license but gonna cal them to see if thats enough.
Robin
Jezza when mine shits itself you can borrow my drag slicks to do a few runs!
Haha, cheers Robin. Would like to see what difference they make.
PR23M3K
What about BRAID WINRACE A ? I read somewhere that they fit on 262 mm brake caliper (but in Honda) without spacers.
ps. weight of the alloys .... 4,1 kg / pc
samg40
Quote from: Robin on August 06, 2013, 10:25:45 PM
Such confidence!
