Author Topic: Guide to change pulley  (Read 3111 times)
Offline xrrich
« on: April 27, 2010, 06:27:37 pm »
Hi im fitting a 65 MM pulley.
is there a brief guide of how to do it and what tools are needed.
Is it best to get a new belt?
Rich
Offline SuperMario
Re: Guide to change pulley
« Reply #1 on: April 27, 2010, 07:17:22 pm »
Isit a toothed pully or a 65mm twinV, if its the twin V just loosen of the charger, unhook the belts and remove the pully with a chainwhip, sorta like a pushbike chain, it holds the pully whist you undo the bolt holding the thing on, only change the belts if they need changeing, no point in throwing money away! o and when you put the bolt back in locktite it in, last thing you want is it coming loose!
Offline xrrich
« Reply #2 on: April 28, 2010, 11:52:43 am »
Its a 65mm twinV. The chain whip like the ones used to get oil filers off that are crap? ha
Yeah cheers for the advice,
How would it run without a chip to suit?
Rich
Offline G40supercharged
« Reply #3 on: April 28, 2010, 01:17:14 pm »
Wrap an old bit of V belt round the pulley before using the oil filter chain wrench thing to avoid damaging the pulley.
Offline xrrich
« Reply #4 on: April 28, 2010, 01:18:29 pm »
Can you run without chip?
How does it differ?
« Reply #5 on: April 28, 2010, 01:19:11 pm »
yes you can run it without a chip, it'll make less power though.
Offline Jezza-7
« Reply #6 on: April 28, 2010, 03:35:46 pm »
You can also use a G-clamp on the pulley which is a good method.
Offline xrrich
« Reply #7 on: April 28, 2010, 03:46:47 pm »
Brilliant, i will have a go over the weeekend
